Home > General > Factory Rear Screens
barrieeld
Before i go taking a seat apart to find the cable that runs down the back of the seat is there any other way to inspect...(check fuse etc) why my passenger rear screen doesn't power up?
I plan on having a go looking at this over the weekend but wanted to eliminate possibilities before "jumping in" Range Rover SC 35th Anniversary 2006
Post #101607 13th Jan 2012 5:45pm
England 2005 Range Rover Td6 HSE Auto Cairns Blue
any connections under the seat ? ..............................
this is handy Wink
Post #101608 13th Jan 2012 5:47pm
barrieeld
i think there connected....are they for the screen wasnt too sure maybe thought they were for the power seat? Range Rover SC 35th Anniversary 2006
Post #101611 13th Jan 2012 5:59pm
i suppose if the seat needs to be removed for any reason then there must be some kind of plug under the seat...i'd look there first.. ..............................
this is handy Wink
Post #101612 13th Jan 2012 6:01pm
Ajay(UK)
United Kingdom 2010 Range Rover TDV8 Vogue SE Auto Stornoway Grey
Scarey's right there will be a connector plug under the seat - This would be the first place to check as it may have been trapped at some point especially if the seat had been moved to either end of its maximum reach.
Then I would suggest checking the plug in the RSE module in the rear near side compartment, after that you may have to remove the screen from the headrest - not as bad as it may sound.
My guess is a loose or damaged cable though Thumbs Up
Andy. 2010MY Stornoway Grey TDV8 Vogue SE with RSE
SWMBO: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Digital Hybrid Tv Tuner, BM54 Tuner with aux input, DVD Changer with Headrest Screens.
Post #101729 14th Jan 2012 7:23pm
Jpickie
United Kingdom 2007 Range Rover Supercharged Vogue SE Auto Stornoway Grey
I had a similar problem and there is a connection under the seat. The cable to the screen is not part of the main harness for the seat but a separate cable about 6mm in diameter. Under the seat in the floor is a compartment with a removable lid, if you slide the seat all the way forward you can just get the fixings out and remove the lid. The screen connector should be one of the first you see when looking from behind the seat. MY2007 S/C - Stornoway / Jet
Post #101739 14th Jan 2012 9:07pm
View user's profile Send private message Reply with quote
United Kingdom 2006 Range Rover Supercharged Vogue SE Auto Bonatti Grey
Often the cables brake and they are fibre optic and very expensive from the main dealer! The other end of the wire from the plug under the seat is a triangular shape found behind the removable panel on the rear of the seat (the panel with the pocket) you can remove this then swap the wires from seat to seat to check if the fault moves!
Be careful not to unplug the headrest motor when pocking around as its a pig to get back in!
Craig Thumbs Up 06 SUPERCHARGED VSE
2012 Facelift
Overfinch Conversion
22" Overfinch Alloy's & GAP Lowering Module
Jet & Ivory Interior with RE & Hybrid TV + LR iPod Kit
BRC LPG
Post #101743 14th Jan 2012 9:56pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
Ajay(UK)
Craig, there is no fibre optics in the specific cable from the RSE Module to each rear screen Shocked - Its an Alpine AV cable which is NOT available as a separate part from the dealer (or so they say!) The green socket on the following picture and the same size black one next to it are the two that send audio, video and power to each screen. If either of these cables was damaged they could be reconnected, they are very small but it can be done Wink
Granted if you damage or crush the orange MOST cable on the far right of the picture it will need replacing but the MOST ring just connects each module and does not go to the headrest screens.
Post #101754 14th Jan 2012 10:42pm
United Kingdom 2005 Range Rover Td6 Vogue Auto Bonatti Grey
Even if the most was damaged you could find a fibre splicer/joiner easy enough these days Smile
Granted not their normal line of work but still, it doesn't need to pipe 10gig+ data rates over many km's Very Happy
Post #101760 14th Jan 2012 11:23pm
barrieeld
Thanks for the help guys...So under the seat I'm looking for a compartment which I just remove the lid off and the cable I'm looking to see if housed property is the 1st cable I should come to? If it's connected property are we looking at a broken cable then?
If so then that will be a new topic! Range Rover SC 35th Anniversary 2006
Post #101767 15th Jan 2012 12:30am
barrieeld
Andy.
Where is this rse module connection the the rear compartment as I'll make sure to check this also. Range Rover SC 35th Anniversary 2006
Post #101768 15th Jan 2012 12:33am
Jpickie
Its one of the first you come to, the cable and connector under the seat is the same shape and size as the blue one in the picture above although for the screen it is a black cable. If its clipped in the correct place it should be next to a smaller dark red connector with a small black cable which is the aerial supply to the armrest phone cradle. The main RSE module is in the left boot compartment when viewed from behind the vehicle. It is mounted vertically adjacent to the opening, lets hope it is a loose connection like i had! MY2007 S/C - Stornoway / Jet
Post #101789 15th Jan 2012 11:38am
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
