![]() | Home > Maintenance & Modifications > Maxxraxx Bike Rack Question |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough Posts: 289
Having contributed to your original thread and as a MaxxRaxx owner, I'm not sure I would...... unless you need to tow at the same time. That Halfords one looked easier |
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 202
Thanks Alister, you've got me thinking now ....... |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 366
I got this one from Halfords - BIKE RACK
| Mutley Member Since: 29 Jun 2011 Location: Reading, Berkshire Posts: 87
Hi guys this is the rack I have fits to the towbar I have had things like the one your looking at but this is far better & easier but it's expensive plus you don't have to remove to get the boot open it slides down to allow access see the video on the site
| Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 66
Well I have had my Maxxrax for years now. Used on P38, L322, Freelander so its a built to last piece of kit. Have the extension to allow for towing at same time too. However, if you buy one remember that they will charge you loads for a swan neck attachment if you have the detachable RR bar because they insist on a professional to install it. Also if you tow a caravan with an Alko stabiliser you will need to order the wider bracket for the standard bracket.
Well I ordered my Maxxraxx today so looking forward to receiving it. I fitted the Westfalia electrics at the weekend so all ready to go....
They go inside the upper section of the boot - thees a strap with a kind of rubber coated cylinder on one end - the cylinder goes inside the boot an when pulled tight touches the trim to stop the strap coming out of the gap - if that makes sense.
So if i am understanding you correctly, it goes around the upper tailgate hinge ?.... 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Yep - I think I ran mine round the side rather than over the plastic spoiler, but can't actually remember as it's been a few years.... |
