![]() | Home > Technical > Check trailer light |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 585
This appears when I attach the lightboard - the lights are fine. Is this just a warning that activates when a trailer or light board is connected.
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 366
Mine does this for around 5 - 10 seconds when you first turn the ignition on (with trailer socket plugged in), then again after you turn it off... maybe it's normal |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 806
Its picking up a fault somewhere. Normal with LED lighting as they take less power, but if they are bulbs then there is a fault with the circuit...
I get what Johnte gets exactly. The only LED bulbs are the front sidelights but they are CANBUS friendly so no warnings in normal use even with the sexy shiver when first turning on |
I have no LED's |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Geneva Posts: 425
If you get the message then there is a fault on the trailer circuit somewhere. Possibly (if you are lucky) it will be low resistance due to poor connection within the trailer plug and the socket on the car. Cover both liberally with WD40. This always resolved the issues on my boat trailers |
I do have converter, to convert from 13 pin - maybe that could be the problem ? All the lights are working perfectly (brand new bike rack) |
