Home > Technical > FBH runs for 2/3 mins then stops?
rwilson
United Kingdom 2009 Range Rover TDV8 Vogue Auto Zermatt Silver
I can activate it via remote (new batt), it starts, fan comes on, I can hear the burner noise from the nsf arch then it stops.
any thoughts?
regards richard
Post #101387 12th Jan 2012 6:43pm
Rambles
2011 Range Rover TDV8 Vogue SE Auto Stornoway Grey
still on OEM battery?
time for a change if you are
Post #101391 12th Jan 2012 7:07pm
View user's profile Send private message Reply with quote
A1GSS
England 2007 Range Rover TDV8 Vogue Auto Stornoway Grey
Mine turned out to be a faulty FBH ECU. Have you got access to a tool to read the fault codes? Graham
Formerly known as Antoniasdad
TDV8 FFRR Vogue in Stornoway Grey / Jet
TDV6 Discovery 3 in Stornoway Grey / Alpaca
Post #101394 12th Jan 2012 7:15pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
rwilson
yep still on OEM
Post #101395 12th Jan 2012 7:15pm
rwilson
dont have access to a fault code reader.
Post #101396 12th Jan 2012 7:18pm
A1GSS
2009 .. unless you're VERY unlucky (jan 1st - Jan 12th registered) your car still under warranty. Get it into the dealer PDQ. Mine cost £1400 to fix... Graham
Post #101398 12th Jan 2012 7:20pm
rwilson
DOR June 09 so till in warrenty Whistle
Post #101399 12th Jan 2012 7:21pm
A1GSS
Only answer. They're very expensive parts, and no LR servicing bits inside, so it means a new one. Graham
Post #101400 12th Jan 2012 7:23pm
SteveMFr
Site Sponsor
As Graham says...
Just FYI - posted in Grahams FBH Fault thread (4th paragraph- 'In the first 2 cases...'):
SteveMFr wrote:
There is nothing in the RAVE on repairing the FBH. I just posted most of the relevant info in the 'Have I got an FBH' thread in general.
Graham, here are the relevant tech docs in English. Don't be put off if it looks like a lot. It is a rather simple device. You just have to weed through the irrelevant info first.
http://www.techwebasto.com/heater_main/tec...63378A.pdf
http://www.techwebasto.com/heater_main/hea...g_Tree.pdf
and the main menu for the docs
http://www.techwebasto.com/heater_car_light_truck.htm
From my past experience here is a list of most common FBH problems (though my experience is based on the older generation of FBH. Should be close to the same):
- bad glow plug (continuity test)
- bad thermal overload breaker (continuity test)
- improper fuel mixture (the mixture is metered by both the fuel pump (precise 'dosage-pump') and the combustion air pump).
- thermal overload due to bad coolant pump
In the first 2 cases the FBH will not even try to run whereas in the latter 2 it will start and shut down without producing any heat.
I'd also contact Webasto and ask who does their FBH repairs in the UK. Here on the mainland it's all Bosch Service Centers (amongst others).
http://www.webasto.co.uk/home/en/html/homepage.html
Let me know if I can be of help if you do attempt the repair yourself.
BTW, the FBH function for the IIDTool is finished. Rolling Eyes We are confirming it in the coming days starting with my RR this evening (as I leave for the US on Sunday).
RRC 2Dr, RRC 4Dr,
P38, and LM
Post #101537 13th Jan 2012 12:31pm
rwilson
Car booked in for thursday, i'll let you know what happens.
Post #103337 24th Jan 2012 5:40pm
Jr-auto-electrics
England 2004 Range Rover Td6 Vogue Auto Java Black
Sounds same as mine,
Think it's a new ecu for FBH RANGE ROVER 04 TD6 FACE LIFTED TO 2012.
MK4 Sat Nav with 2012 maps :@>
Post #103370 24th Jan 2012 8:59pm
rwilson
Popped it in to Lookers Battersea, they were very helpful. Its going back next wednesday for a day!!!
watch this space...........
Post #103672 26th Jan 2012 3:31pm
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
