Well I went at it today with a decorators palette knife, the type you would use to apply filler or scrape wallpaper off with. Worked a treat, and the tread plates pop off quite easily. The A post lower finisher more or less fell off after that, with one of the clips already broken.
As for my cable run, I had to remove the B post upper and lower covers and the finisher (the covers come off together, and you have to bend then outwards in the middle to split them apart and release the top fixings), the rear tread plate, the lower D post finisher, then ran the cable from the audio / tv gubbins corner, up over the wheel arch, down under the rear tread plate and tucked under the carpet, up past the B post but under the B post lower finisher, back under the carpet and the front tread plate, then into the cavity revealed by the A post lower finisher, dropped the footwell closer and ran the cable across the top of that.
My target is the coin tray in front of the gear lever, where I am fitting two push switches. This seems to be the only place where a) there is enough room below for the rear of the switches, b) a fairly straight forward cable run to it, c) accessible by both driver and passenger, d) least destructive - the two holes I will make can always be covered over with a piece of black plastic if returning car to normal.
Note: Rave says to disable the SRS if removing the B post, I presume this is only if you will be tackling the pre-tensioners on the seat belts.
Have "RSW All Comms" in Hampshire - happy to help
Current Combustion Engine Transports:
Range Rover 2002 TD6 HSE Alveston Red, Sand Leather
Audi 2004 Cabriolet Sport 3.0 (Amulet Red)
Mazda Eunos 1990 (Brilliant Red)
MG Midget Mk 1 1962 (undergoing restoration) (to be Nightfire Red)
