Home > Technical > Can I plug the car into the mains?
Baben
South Africa 2010 Range Rover Supercharged Vogue SE Auto Alaska White
Ctek25000 will do the trick 20A in supply mode and safe - I think you need more than 6A to keep all the gizmos running. Just a bit expensive tho, compared to a supermarket special, but hey, if you can afford a FFRR.... Ex: D3 TDV6 SE
Post #96867 9th Dec 2011 5:12pm
View user's profile Send private message View poster's gallery Send e-mail Reply with quote
dan_uk_1984
6A will run the radio and interior lights. Admittedly not the heated seats and screen Laughing
Post #96886 9th Dec 2011 5:24pm
England 2002 Range Rover Td6 HSE Auto Alveston Red
Cripes!
Have "RSW All Comms" in Hampshire - happy to help Smile
Current Combustion Engine Transports:
Range Rover 2002 TD6 HSE Alveston Red, Sand Leather
Audi 2004 Cabriolet Sport 3.0 (Amulet Red)
Mazda Eunos 1990 (Brilliant Red)
MG Midget Mk 1 1962 (undergoing restoration) (to be Nightfire Red)
Post #96912 9th Dec 2011 7:49pm
mrblonde
2003 Range Rover Td6 Vogue Auto Adriatic Blue
EVOeng wrote:
I would avoid using an ordinary car charger. The purpose of these chargers are to charge the battery up as soon as possible for convenience – this can often damage the battery if used regularly.
I would instead opt for a battery conditioner, these are designed to stay on the car for prolonged periods causing no damage and keeping your battery in full health. They (CTEK) can be had for very little money too; and they can come with a Cigarette adaptor so no need to have the bonnet open, the wire just slips through the door shut.
Hi mate
Am looking at the CTEK's at the mo for my TD6, and the cigarette plug adapter for it, will it charge overnight as wasnt sure if the cigarette lighter in the car was a constant live?
Cheers in advance
Post #104031 28th Jan 2012 1:09am
View user's profile Send private message Reply with quote
A1GSS
The 12V socket in the boot is always live (in my case anyway). The cabin ones are not. Graham
Formerly known as Antoniasdad
GONE: TDV8 FFRR Vogue in Stornoway Grey / Jet
TDV6 Discovery 3 in Stornoway Grey / Alpaca
Post #104039 28th Jan 2012 1:57am
England 2004 Range Rover Td6 Vogue Auto Giverny Green
Both cigarette lighters in the cabin and the boot aux socket in the boot are permanently live in my car.
There's two options for wiring to them in the wiring diagram.
I use a Ctek MXS 7.0 plugged into my front socket.
You need to buy the adaptor lead seperately to plug into sockets.
Post #104061 28th Jan 2012 10:22am
farrellelion
Portugal 2002 Range Rover Td6 Vogue Auto Java Black
What's the advantage in using the sockets? I'm clamping my CTek MXS 7.00 ,directly onto the2 points designated for jump leads, exterior to the battery box--the power comes in under the bonnet, above the vertical air vents inlets. The bonnet remains closed and thealarm on.
I get the idea that Dan thinks 6 amp is not really enough, and Baben is using 20 amps. Does any one know, how many amps are necessary to supply the battery keeping charge at 100 o/o , with no sulfating at all? 2002 Vogue TD6
2001 Defender 90 TD5
Range Rover Classic 1994
Mercedes Benz 220 S Sedan 1959.
Post #104194 29th Jan 2012 12:35am
View user's profile Send private message Send e-mail Reply with quote
pretlove
United Kingdom 2003 Range Rover 4.4 V8 HSE Auto Zambezi Silver
Nice to see you back dan Thumbs Up have you brought a new range rover Question "RANGEISM WILL NOT BE TOLERATED"
Post #104197 29th Jan 2012 12:56am
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
