![]() | Home > Maintenance & Modifications > Locking doors when driving off... |
| noddy Member Since: 23 Feb 2009 Location: Birmingham Posts: 1070
Is this a programmable option? 02 Vogue |
| RRUK Member Since: 08 Jun 2007 Location: UK Posts: 3295
It can also be done on the RR Sport by the driver via the instrument binnacle. I'm afraid its a dealer issue. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
| Kilovolt Member Since: 07 Feb 2010 Location: Derbyshire Posts: 105
Out of interest, on an MY10 it is a settable option on the shiny LCD instrument binnacle menu.
| claud Member Since: 15 Apr 2009 Location: Godalming Posts: 100
The dealer should be able to give you a form to fill out all the options you want set, Hunters charged me £60 to have auto lock doors and headllamp delay (you have to pull the flash switch for this though so pretty damned useless). Bit galling to be charged for this after being parted with £40k for the vehicle. 2011 Evoque Prestige SD4 Lux + Adaptive Dynamics
| SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 120
| axle Member Since: 28 Oct 2007 Location: argyll Posts: 630
Whilst on a 2010 you can now select auto-locking on pulling away from the user options to keep up with Land Rovers comedy approach to electronics you still have to hit the button to unlock them when you want to get out or pull the individual handle twice . |
| Vogue Member Since: 31 Jan 2008 Location: The Highlands Posts: 1734 |
its meant to be like that. Its to prevent thieving illegals from opening the door and nicking your handbag when you pull up at the lights, junction, Mcdonalds, garage etc etc.
| StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117
Vogue i feel i must point out that we have some perfectly fine home grown thieving junkie basturds and if it was an Olympic sport i feel we would do well |
| RRVSE Member Since: 18 Apr 2009 Location: Bury (near Manchester) Posts: 278
I set the headlight delay myself via a thread on this forum and works fine. Obviously I have to flash the lights as I get out to trigger the delay, but it's no hardship. Think it was just a case of getting in the car, locking the doors, then holding the LR button on the keyfob whilst holding the headlights on flash until the words 'headlight delay' appeared on my LCD display. Steve
| SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 38
On an 02 this is only programable by using TestBook/RovacomLite or similar, it is not available by using the dash buttons.
| Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 442
I must make a trip to the dealers as I'd like the "follow me home" lights activated.
| VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 255
Do a search on the ''other forum''.
| All times are GMT |
