![]() | Home > Technical > iBus + Resler Interface + Navcoder |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3755
For those interested, as you'll know a few months go I bought the Resler Interface. But I was moving house, then xmas happened etc so not had a real chance to have a play with it.
| noddy Member Since: 23 Feb 2009 Location: Birmingham Posts: 1070
Why would you want to do that? 02 Vogue |
Because it's the precursor to programming your own functionality and changing dealer spec options. |
oh, ok. Can i make my doors lock when I drive off using this then? 02 Vogue |
Yes, if you can figure it out. |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1249
I've just used the USB interface lead with Navcoder and sucesfully enabled tv in motion, had a bit of an issue with my laptop saying com3 was in use but managed to get round that. Seems like a good bit of kit. 2006 Mercedes CLS
Where did you take your iBus feed from in the end? |
Just plugged it in line with the TV Tuner, connected straight away once I got the laptop sorted. 2006 Mercedes CLS
Just remember next time you plug it in it should go into the same USB port, if you put it in a different one the system will assign it a new com number. Not a problem as long as you connect it all up and THEN open Navcoder it should auto detect which com port to use.
Yeah cool, I'll remember that. I'm gonna have a play around tomorrow after work. 2006 Mercedes CLS
| Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 98
Ive just recieved the Resler Interface and paid for Navcoder and can I hell get it to work
I have fitted an intravee and Alpine ipod controller so its easy enough to get to the ibus lead in the glovebox
Are you using two wires or three?
| All times are GMT |
