![]() | Home > Technical > Ventilation fan |
| adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 220
If you are referring to the ECU fan it's at the bottom of the big box in the right side of the engine bay (you need a T30 bit). You shouldn't remove it, just spray some lube on the bearings if the noise annoys you. |
| elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 700
No its not the ECU fan. I've had the lid off the box and that wasn't kicked in at all. I noted a sensor at the top of the box which I assume only kicks the fan in when it gets hot in there?
| All times are GMT |
