Home > Maintenance & Mods (L322) > *** 2010 in car pc project UPDATE *** |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
I am a big fan of the Asus EEEPC range of nettops (daily use)
20th Feb 2013 1:31am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7736 |
You'd need some sort of momentary relay for the power on. wired to ignition live, to replace the PC power on switch.
20th Feb 2013 7:56am |
The largest selection of DC-DC power supplies and start up / shut down controllers AFAIK is the MP3car.com shop. Did you want to avoid ordering from the US?
20th Feb 2013 3:11pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3052 |
Matt, I've got an asus eeeeepc hardly used if you are interested. Pm me if so. |
20th Feb 2013 5:51pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi mate, i have a asus eee pc laptop already i am more thinking an asus eee box might be the way forward if i can find a suitable way to power it automatically. matt |
20th Feb 2013 6:11pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Matt
20th Feb 2013 6:44pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi matt,
20th Feb 2013 7:20pm |
ok after an entire day of researching and looking for ideas of using an asus eee box then contemplated on building a custom mini-itx machine the answer has been staring me right in the face all along i am going to use one of my HP Compaq D8200 ultra slim desktop computers i have spare at home it has a intel i5 cpu, 4gb ram, SSD hard drive, slot loading dvd and luckly it is powered by a 19v external PSU block which means i can use the 12v DC to 19v DC converter i found for powering the asus eee box idea i had. http://store.mp3car.com/Carnetix_CNX_P1900...wr-010.htm
20th Feb 2013 11:27pm |
ok so i have spent the day installing windows 7 and the range rover software on to the PC i will be using in the car, and as always have hit a bit of a stumbling block When i originally designed the range rover software it was designed for a screen resolution of 1024 x 600 which is what the screen res of the first device i was going to use supported. Now i have come to use a different device it doesn't support the 1024 x 600 resolution. I have tried using powerstrip to create a custom resolution but the Intel HD graphics drivers dont allow you to do that.
21st Feb 2013 6:22pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
I certainly can't add anything of a technical nature, so will make do with posting to show my support - a great project, looks like you can achieve some really useful functionality, keep going Matt! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
21st Feb 2013 9:53pm |
matt, i stopped the project due to the problems with the switches,have you overcome this, i got very close with the joycon unit but just could not get it right, V8 facelift Range Rover Autobiography 22" wheels.
22nd Feb 2013 12:38am |
Hi Dave, not overcome it yet - but i have found a little more info on the ardunio my plan to start with is to just get some standard buttons to work (not using the factory circuit board to start with) then once the software works with the standard buttons i will know the code works and i will try again to get the factory circuit boards to work.
22nd Feb 2013 1:37pm |
here is my board, its a 2.2ghz with 1gig of ram, it is only 200mm by 200mm with one pci slot for the camera card,it has a full size atx plug so no probs with my car pc power supply
22nd Feb 2013 7:00pm |
davetrees Member Since: 01 Dec 2009 Location: Sunshine Coast Posts: 5 |
daveo did you have any luck with the arduino chip I sent you? |
23rd Feb 2013 10:27am |
