![]() | Home > Technical > Loss of power when engine is hot |
| elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 700
I'm no expert but it may be worn pumps or failing injectors. A leak off test on the injectors should let you know if any individual injector is playing up. Plugging in to a Landrover computer should tell you if there is a fuel pressure problem.
| nielsen Member Since: 26 Aug 2010 Location: Sweden Posts: 7
Just tryed changing the airfilter today. Took it out for a spin. Engine cold max rpm 3500 and after 5 minutes when the engine got warm it changed to max rpm 2000. Just don't get it.
| kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63
| Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 50
Turbo?? |
It is the same in sport mode. Have also tryed turning dsc off.
| darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 417
high pressure fuel pump next to fuel tank 2002 td6 vogue, 06 supercharged facelift
It sure was the fuel pump. Thanks for all your help |
nice to see its fixed |
| All times are GMT |
