Home > Maintenance & Mods (L322) > Broken locking wheel nut |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Hi Bigbangman,
29th Aug 2010 3:30pm |
Bigbangman Member Since: 10 Jun 2010 Location: Worcestershire Posts: 51 |
Hi Delamo,
29th Aug 2010 5:28pm |
Your eBay link doesn't seem to be working Bigbangman so I can't see what yours are like...
29th Aug 2010 5:45pm |
DeltaC Member Since: 23 Mar 2010 Location: Aberdeenshire Posts: 148 |
The extractors you are refering to are probably made by Irwin - Great tools. If you can get the rotating cap off with a chisel, they should go on no problem. They are easier to use with an impact wrench though as that allows you to push, while the wrench does the turning.
29th Aug 2010 6:19pm |
Indeed DeltaC - it was infact your information (and dan_uk_1984) that helped me when I had this very problem with my nuts a few months ago! - Thank you |
29th Aug 2010 6:46pm |
Hi, thanks for the replies:
29th Aug 2010 6:52pm |
No problem Bigbangman - hope my experience helps you out
29th Aug 2010 7:07pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I looked at a wheel nut remover socket device in Halfords. if I remember rightly, I think they use a reverse thread and somehow as they go on they crush the outer spinning cover against the real internal head, then you just use a normal socket set to unscrew them off. Obviously, you then need to buy a new set of locking wheel nuts. Kit is £17 - Link below...
30th Aug 2010 2:36am |
Steve,
30th Aug 2010 11:31am |
Hi DeltaC, thanks for clarifying. Steve
3rd Sep 2010 12:53pm |
