![]() | Home > Maintenance & Modifications > Can you change the TV to receive a Digital signal! |
| RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 348
Buy a newer Range?? If you have nothing nice to say,say nothing at all. |
| stan Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 8137
if you have only an analogue receiver then you'll have to buy a digital or hybrid one..plenty of posts on the forum re this , do a search... ..............................
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
Search on eBay for BMW Hybrid:
| daveo Member Since: 21 Oct 2009 Location: london Posts: 1471
there are two types, 02 to 05 bmw system 05 onwards ford based system..
| kil2508 Member Since: 05 Sep 2010 Location: Wales Posts: 20
Cheers for the replies guys, glad it can be done, just got to buy a Range rover now! |
| Discocuzzy Member Since: 02 Aug 2010 Location: Surrey Posts: 94 |
hi, you use the pre touch screen, the res its not brill but is good enough to do the job, there are a few people working on a screen replacement with a high res, just the screen so you get to keep the origanal unit and looks V8 facelift Range Rover Autobiography 22" wheels.
hi discocuzzy i have not seen centrafuse, would like to see it if you have a link, i use carx as it replicates the range rover menue so when you switch over it looks the same... V8 facelift Range Rover Autobiography 22" wheels.
Like it Daveo...what system you running, where is it hidden etc?..i have just aquired another tablet |
hi, my set up is all in the boot, i use an acer one netbook with an external hard drive, this is connected to the car via video interface lead from the tv tuner, and is controlled by the usb ibus interface, this allows you to control it from the front, as i said it replicates the menu so unless you know about car x you are none the wiser.
Are you using a 12 volt power supply that auto shuts down/powers up with the ignition?...also where do you get the leads to connect the TV?...sorry if to many questions pal |
Last one Dave i promise!!!. i run garmin sat nav for pc in the defender, would the standard screen allow you to run this as well? |
hi yes, the 12v supply is on the ignition, the pc is set to restart after power fail so when the batt goes flat as soon as the ignition is on it will restart but it very realy goes that far as the standby life is great,
