Home > Technical (L322) > Viscous fan won't dis-engage |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Hi All,
17th Jul 2013 5:43pm |
Yip new viscous coupling or run it in this weather and just leave the AC on and you have enough to cool the engine as long as the cooling system is in good nick Its more for the very hot climates and lots and lots of slow moving traffic really.
17th Jul 2013 7:58pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
Driving in south of France at the minute , high 20s temps. I have my coolant temp showing on hidden menu, it's been reading between 88-100degrees depending on terrain, included some big motorway hills . Typically 90-92.
28th Jul 2014 12:28pm |
Most likely as thinner air offers less cooling and if the engine is working hard it will be hot. the AC fan is more than able to cope in most conditions without the viscous unit IMO. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Jul 2014 12:53pm |
As per my original post, if I red lined my TD6 (which I had then) the fan would invariably disengage after a lot of howling!
28th Jul 2014 12:57pm |
Yeah but the TD6 should redline every now and again anyway to clear the soot from the exhaust regularly anyway and help clear crud from the exhaust turbine vanes/housing that builds up FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Jul 2014 1:52pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I had a TD6 in Scotland and was constantly having to rev the engine hard after re start or next morning after towing something to get the viscous fan to dis-engage , I now have a supercharged in WA ( and I don't have to tell you how hot it can get ) and hardly ever hear the thing kick in so I would have to say its a minor failing of the BMW desiesel . 2008 MY Supercharged
28th Jul 2014 2:24pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Don't rev it to max!! The fan is designed to run at below engine revs, it may disintegrate with the disastrous results, tales of blades puncturing the bonnet! |
28th Jul 2014 5:50pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Just remove it
28th Jul 2014 10:30pm |
TOF Member Since: 13 Mar 2013 Location: Gloucestershire Posts: 53 |
Is this an easy thing to remove... It is really starting to annoy me and is so loud. I only have to be in traffic for a couple of mis and it is wooshing all over the place... |
17th Nov 2014 8:23pm |
Easy to remove? If you have the right tools. You will need a couple of viscous fan spanners, recognition that it is on a left handed thread, and some patience to release the fan shroud. .
17th Nov 2014 10:08pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Did mine ... see link below for some tips
17th Nov 2014 10:47pm |
Is it ok to do it on an 06 supercharged or will it mess up the air con...
18th Nov 2014 7:55am |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
The visscous fan on the Supercharged also has an element of ECU control so it will screw things up if you remove it..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
18th Nov 2014 8:12am |
