Home > Technical (L322) > AMK Compressor Troubleshooting? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
You should have disabled the system with the IID tool before you changed the bags, you then re-enable it. You have to have it on the ground to fill it with air, if it senses that it's got it's wheels off the floor it won't do anything, you can lower it until the wheels are at about the right height and then refill it....
26th May 2015 10:39am |
brucebaner1 Member Since: 03 Feb 2015 Location: Virginia Posts: 8 |
Thanks Pete! I will tighten and review the IID tool. Will the bags be noticeably filled with air? |
26th May 2015 3:17pm |
If they have air in them they will be virtually solid, very difficult to flex them with your thumb... Pete
26th May 2015 5:47pm |
So I reflashed the AMK ecu last night (using IID tool), started the truck tonight and the compressor is not starting. Do I need to do something similar to a hard reboot of a computer? |
28th May 2015 3:37am |
It should just work, check the plug is properly home, then check if it has power to it, start the car, press the suspension up button, this should turn the pump on, then check if it has power to it on the thick red/white wire, if no power then it could be fuse 18 in the boot, 50amp or the relay that lives there as well...
28th May 2015 8:35am |
Thanks again; I will try these things tonight. I also research something about a hard restart of the battery. Fingers crossed!! |
28th May 2015 11:33pm |
I rechecked everything and reflashed. No difference. I even tried the battery reset (I think.....). BUT I did notice my wife must have accidentally lowered the truck. I noticed my tires seem to be touching the floor. I know I've heard from many resources that the car should not be lowered prior to the bags being filled with air. Since my compressor is not working, my bags are not filled with air. Do you think lowering the Range caused a problem? I also checked fuse 18; no issue with the fuse. |
30th May 2015 11:13pm |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
Have you got all the doors shut when you wait for it to fill? The system is inhibited when doors are open to prevent the car moving as passengers are entering or exiting.
1st Jun 2015 12:24pm |
It's only the doors, not either bit of the boot!! Pete
1st Jun 2015 2:51pm |
