Home > Maintenance & Mods (L322) > service engine soon light
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Got my first "service engine soon" light come on today after first start up. It flashed a bit, went off and didn't return for the next 4 starts. Just to mention I've had 3 no start issues over the past 4 months. That is to say it didn't start on the first key turn but did on the second try. Here are my iidtool faults:
Model
L322 - Range Rover 2004
Vehicle scanned on Nov 24, 2015 9:56:04 PM
IIDControl 2.6.1 Android - IIDTool BT V3.0 B2134
ABS-Brake Module
• 0x61 Steering angle sensor initialisation
• 0x5A Temporary system deactivation
ATC-Heat / Cool
• 0x30 Air quality sensor line fault
BPM-Body Processor v4
• 0x59 Driver door central locking mechanism broken
• 0xA7 Passenger door mirror horizontal potentiometer: defective
• 0xA6 Passenger door mirror vertical potentiometer: defective
• 0xA4 Driver door mirror vertical potentiometer: defective
DSM-Driver Seat
• 0x11 Steering column radial motor - transmission error
HID-Left Headlight
• 0x2A Ignition voltage <7>115 Volt, operating voltage out of tolerance
HID-Right Headlight
• 0x2A Ignition voltage < 7.5 volts
IP-Instrument Pack
• 0xBD EBV function fault received from ABS ECU
• 0xBF Instrument Pack checksum incorrect
LCM-Light Control v11
• 0xC ECU EEPROM fault
• 0x15 Brake light switch line short circuit to ground
• 0x57 Air suspension active/inactive
• 0x5E Radio remote key battery fault
• 0x0094 Unknown
• 0x0095 Unknown
PATS-AntiTheft
• 0x3 Key 0 - Random code tolerance increased
• 0xF Power-on Reset
TBOX-Transfer Case
• 0x5212 Battery undervoltage (0x5212)
Anyone see anything to cause me to cancel my 600 mile holiday trip? Thanks
Post #358594 25th Nov 2015 4:31am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Clear faults / battery reset, drive for a bit and see what pops up. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #358640 25th Nov 2015 12:35pm
