Home > In Car Electronics (L322) > Caller id name on the screen? |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
I have a 2012 TDV8 but when using my iPhone 6 via Bluetooth , the screen only shows the number of the incoming caller not the name associated with them within the address book.
7th Feb 2016 10:49am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7736 |
On my L405 it's a little slow - usually takes a couple of rings before it manages to work out the name of the caller
7th Feb 2016 11:23am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
2008 seems to work fine with iPhone4. I would have thought the 6 would be significantly better. |
8th Feb 2016 12:39am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
On mine it's a bit hit and miss , if i receive a second call from a person on my list in any given journey it will show the name but usually not on the first call just the number shows and sometimes it just says incoming call . I need to pay more attention to be sure though . 2008 car and iPhone 6+ by the way . 2008 MY Supercharged
8th Feb 2016 2:14am |
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 679 |
Did it work correctly with your previous phone ? |
8th Feb 2016 3:18am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
My 2007 is hit and miss with an iphone 5 - sometimes it works fine, sometimes it doesnt show names or load the phone book and sometimes it just decides not to pair at all! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
8th Feb 2016 1:51pm |
I had a similar problem with a 2012 range rover sport. It turned out that if you go in to the menu there was an auto download button that was set to off. |
8th Feb 2016 1:59pm |
It did work on my earlier L322 but not on this. I'll see if there is an autodownload option tomorrow. CURRENT : FFRR 2012 4.4 TDV8
8th Feb 2016 6:45pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
2008 and iPhone 6, numbers only Many thanks
8th Feb 2016 7:42pm |
