Home > Maintenance & Mods (L322) > Tdv8 coolant reservoir level |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 123 |
How it should look cold.
6th May 2016 12:42am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Ok. That settles it thanks Paul. ______________________________
7th May 2016 10:40am |
First time around give your self 6 hours. Pete it's a xxxx in the butt to have to do it, but I'm glad I did mine, as while doing it I also cleaned out the intake, checked the egrs, and replaced a few seals, (throttle body,butterfly valve, egr pipe gasket) and to me it looked like they had been leaking. I've never seen smoke again since no matter how hard I boot It.
10th May 2016 3:29pm |
Thanks again Paul.
10th May 2016 8:37pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
Pete have you actually tried bleeding the system? I suspect you still have a leak but there's a little plastic dial on the top of the expansion tank which you open up, run the engine and it self bleeds. A search or the WSM should reveal the correct procedure. Ed |
10th May 2016 11:41pm |
Thanks I'll give it a try when I get back. ______________________________
11th May 2016 1:41am |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Is there any other 'jobs' or checks worth doing whilst doing the thermostat housing repair? |
11th May 2016 8:09am |
Have you done the EGRs? You'll have gained access to them by then. Ed |
11th May 2016 8:48am |
When you say coolant tank, are you referring to over flow tank. if that was leaking I'd expect you to see coolant onthe ground. Apparently the egr coolers can also leak, they are bolted to the end on the egrs.
11th May 2016 10:21am |
thanks again Paul.
11th May 2016 11:23am |
Are the egr valves themselves, cooled? |
11th May 2016 12:10pm |
The cooler is for the exhaust gases afaik. ______________________________
11th May 2016 1:12pm |
Egr valve blue, egr cooler red.
11th May 2016 10:36pm |
So the egr valve itself doesn't have cooling water connections.
12th May 2016 11:50am |
