Home > In Car Electronics (L322) > Question for all you Android upgraders, Pete! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi all and Pete
28th Sep 2016 12:36am |
Well I'm sort of on the same wave length as you, I was actually planning to run everything except power and i-bus to the boot for connection, and although I have to go past 2 of the doors there is no way I'd be trying to connect to them except via the boot
28th Sep 2016 11:16am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
No bother in extending the cables from the short leads... as said none of the FF aerials work very well with anything else...
28th Sep 2016 11:45am |
Yesterday I couldn't spell Engineer... Today I are one!
28th Sep 2016 11:50am |
Testarossa1967 Member Since: 09 Jan 2016 Location: Warrington , Cheshire Posts: 29 |
Hi , I have the Dynavin N6 unit that was fitted a few weeks ago with DAB but not the TV , I put the cable in to the boot as my amp is still ok , feel free to look at my posts and if you have any questions get in touch and I'll do my best to answer |
28th Sep 2016 12:51pm |
28th Sep 2016 1:11pm |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 |
The only concern I have about removing the DSP is that you will still need some form of crossover in order to prevent the smaller speakers from getting slowly baked.
28th Sep 2016 3:07pm |
Good point bud
28th Sep 2016 3:44pm |
I started pricing up passive crossovers, and by the time you've spec'd them with a sufficiently low crossing point for low frequencies in the car (≈600Hz from memory) the price is such that you're well on the way to paying for an active unit.
28th Sep 2016 4:07pm |
Mines been done for ages, no crossovers, use it all the time... no issues whatsoever with the speakers, still sounds great,
28th Sep 2016 4:40pm |
No your not wrong, they do have an active sub, to go with the active DSP driver, only I'm screwed as I can only do binary connections....... on or off...... so I haven't the foggiest idea on how to turn it all on....... hence the totally passive route and an active sub wired to the sub out on the head unit and and the remote power lead
28th Sep 2016 4:48pm |
Wot you've not even upgraded to marine grade speakers Ok, you've sort of convinced me to just wire it up as is and see, or should that be hear If I don't like it then I can add the crossovers and sub after, fortunately it's all in the rear cubby, apart from the sub out connection at the head unit.... which I might just extend in to the cubby to save the inevitable D'OH! if it sounds pants Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
28th Sep 2016 5:24pm |
nip848 Member Since: 26 Mar 2016 Location: London Posts: 29 |
I upgraded to an Android unit, very happy with the outcome.
29th Sep 2016 2:23am |
The closest analogy I can make to this is “I took the air filter out of my car, and it will still go down the motorway at 100mph, and doesn’t make any funny noises”. However you are now forcing the engine to process something (foreign object particles) outside of its design operating range, and in so doing you will not be get the best out of it, and worse you will be shortening its life. When you connect a mid-range speaker, or worse still a tweeter to a full audio spectrum electrical signal coming out of a power amplifier the result is that the lower frequencies will cause (1) saturation of the magnetic ‘system’, and; (2) heating of the inner delicate copper coil. 1 will result in degraded audio performance, and 2 will will shorten the speaker’s life. As a professional electronics engineer I maybe (am) taking a very purist approach, but I fail to understand anyone who wantonly doesn’t get the very best out of a given system, and at the same time is actually damaging one of their own possessions. At work we term it ‘ACD’, but then I'm probably OCD. |
29th Sep 2016 8:00am |
