Home > In Car Electronics (L322) > Electric windows |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
Not quite sure whats going on here, but changes the front struts and airbags on my car today and left the window open whilst I disconnected the battery, fired it all back up and the window wouldn't close (drivers only). Could hear the motor click to open, but wouldn't close.
28th Oct 2016 9:15pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
With window up, and wires as they should be, doors closed, try a battery disconnect and leave it off for @ 1 hour. .
28th Oct 2016 11:47pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I would put the wiring back the way it was, with the window shut, disconnect the battery, go down the pub, have lunch and an afternoon snooze and then reconnect... failing that just wait the 30 mins And hopefully it should go back to normal... the windows don't have limit switches.. so one of the many computers in the car works out how long is required to open / close the window... when you disconnect the battery it forgets where it is and what its doing, so it has to relearn.... your asking it to close a window that it thinks is closed already I would try that before you go in to the logic circuits and try all manor of
28th Oct 2016 11:52pm |
So in theory... I could just disconnect the battery for an hour, and then when I reconnect it should work?
29th Oct 2016 10:19am |
I have noticed that there appears to be 2 relays in the wiring diagram you posted.. possibly one has gone down... but what is on the drawing what is actually there are 2 different things, as I suspect that LR will be using solid state relays (chips) to do the job... 1 cos they is cheap, and 2 cos they make no noise...... if that is the case then it will be a new module required... but hopefully the reset will sort it, they tend to get the hump when you mess with them and they do all sorts of silly things to tell you they have the hump.....
29th Oct 2016 5:15pm |
