Home > Technical (L322) > Turbo hose help!! |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 |
How on earth do you get the turbo to intercooler hose on the intercooler end?
28th Oct 2016 4:28pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
http://www.fullfatrr.com/forum/topic38330.html
28th Oct 2016 4:40pm |
Just read your thread thank you!
28th Oct 2016 4:42pm |
Hi sorry can't remember which groove it went into. I do now rember that the clip rotates on the hose which lifts it up so you can push it onto the intercooler then just rotate the clip and it should grip. Try it before you push the hose onto the cooler and you can see how it works. Run you finger around the intercooler groove to make sure it's clean or the clip won't grip and it pops/pulls off.
28th Oct 2016 4:59pm |
Really stumped now, I could hear that there was a leak somewhere, but couldn't feel it from that end of the hose.
28th Oct 2016 9:00pm |
Sorry to hear that .
28th Oct 2016 9:15pm |
Thanks for your reply again Simon
28th Oct 2016 9:18pm |
No probs Steve,
28th Oct 2016 9:32pm |
Cheers, Hopefully isn't too bad. Lost my patience with the car today after fixing the suspension, got that working and thought a 10 minute job to change the turbo hose, RAVE doesn't even describe in detail how to do it, more of a guess job! |
28th Oct 2016 9:36pm |
Just another thought, I have just been reading the BMW forums and apparently the connections on the 335d (same pipe connection) has a seal in which is meant to be salvaged when removing.
28th Oct 2016 9:40pm |
Just had a look at my spare in the garage. It looks like it's bonded onto the pipe- can't see a seal but the pipe is defo glued/bonded on. ( I can't even cut the damned think off).
29th Oct 2016 9:04am |
Thanks for that.
29th Oct 2016 9:09am |
picture worth a thousand words. any help?
29th Oct 2016 9:16am |
That's the hose that blew off there, just put it back on now!
29th Oct 2016 10:15am |
29th Oct 2016 10:49am |
