Home > Wheels & Tyres > Speedo adjustment for different wheel/tyre combinations |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1328 |
With there being so many options of wheels/tyre combinations, presumably all with differing rolling diameters, how do you deal with recalibrating the speedo to read correctly?
10th Nov 2016 2:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
you cant Rob, theres no calibration i know of....
10th Nov 2016 2:35pm |
Lup Member Since: 18 Aug 2016 Location: Västernorrland Posts: 10 |
Typically the speedo is showing higher speed than it actually is with 5-10 %. This has been true for most cars I've owned and I assume our RRs are similar. You can check your Speedo by comparing it to a GPS with a speed indication. The GPS is independent of rolling diameter and is showing a more correct reading.
10th Nov 2016 3:29pm |
I thought these days with wheel speeds being "read" individually by the cars various systems that speedometers were more accurate compared to the old cable operated ones, which I agree were always out by around 10%. 2017 4.4 SDV8 Autobiography
10th Nov 2016 3:37pm |
this is a new feature on the iidtool and i've done this as well going from 20'' to 21''...whether this makes any difference i dont know... ... - .- -.
11th May 2017 10:02pm |
Presume that's the latest firmware then Stan. Need to update mine.... 2017 4.4 SDV8 Autobiography
12th May 2017 11:10am |
i cant remember updating for a while Rob so not sure what version it is .. ... - .- -.
12th May 2017 11:51am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
Stan, can you let me know how you worked things out please? I have seen various calculators on the www, but would like to know how you calculated things just to get it right.
12th May 2017 6:19pm |
not sure what you mean Stu...there's a part in the iidtool cff that lets you put in your wheel size and because i have recently changed from 20" to 21" i imputed 21"...
12th May 2017 6:46pm |
What I'm not sure of is how to work out the rolling radius and rolling circumference. My tyre size isn't on the list of options Current: TDV8 (3.6) RRS HSE
12th May 2017 7:11pm |
Stu, your new 255/55-20 tyres are slightly bigger than the standard 20" so the speedo will read more or less spot on ..... ... - .- -.
12th May 2017 7:18pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7623 |
The 255 is mm and is width. The 55 is a percentage of the width, so the sidewall is 55% of 255 mm.....
12th May 2017 7:23pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
there is a very easy and simple way how to adjust the speedo
12th May 2017 8:31pm |
Thanks Guys, I'll have a fiddle over the weekend and check against my garmin to see how things are Current: TDV8 (3.6) RRS HSE
12th May 2017 9:03pm |
