Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
JPHC Member Since: 07 Sep 2015 Location: Kent Posts: 303 |
Thanks for the reply mate. Hmm might have to do that then...
29th Jul 2016 2:29pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
You would need an extra 2 tracks on the slip ring as the heating element has 12+ Gnd and data, and the paddle shift system needs 12+ Gnd and 2 datas (basically Gnd connections for up and down shift)
29th Jul 2016 3:26pm |
Does make sense mate. Will have to rip the wheel apart this weekend and get the multimeter to work to get a good idea of how it's all setup for myself. Jordan
29th Jul 2016 3:40pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
if i can remember i used the ground for the air bag for one and the live for the switches for the second V8 facelift Range Rover Autobiography 22" wheels.
29th Jul 2016 9:46pm |
hi
30th Jul 2016 5:50pm |
That would be great. Craig, you got such a thing mate? Jordan
1st Aug 2016 10:54am |
Harris24742 Member Since: 18 Dec 2016 Location: London Posts: 3 |
Hi all. A newbie here. Can i retrofit a 2012 vogue's steering wheel on 2008 vogue? I know the paddle shifters can be installed after a little modification of thw wiring but the control switches is what bothers me. Would the nav and other controls function similarly? I mean is it a bolt on setup?
18th Dec 2016 2:59pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7905 |
Pretty sure the "bus" systems are different so no you can't swap the airbag and switches, I think the bare wheel is the same though but you would have to check... Pete
18th Dec 2016 4:12pm |
I actually want to put the 2012 instrumental cluster and the 2012 steering wheel. Paddle shifters aren't needed but would be nice if i could manage the wiring. What i don't know is that whether or not the control switches can be installed on 08 |
18th Dec 2016 5:26pm |
You can't fit a 2012 instrument cluster to a 08 L322. The MY59 L322 use a virtual instrument cluster and had a complete change in terms of wiring and CAN BUS. Pre MY59 vehicles use a 29bit CAN BUS whereas post MY59 vehicles use an 11bit CAN BUS network. The two are not interchangeable.
18th Dec 2016 7:21pm |
2010? Or is 2010 and 2012 same steerings? Because there's no point of putting this if inwont be able to use the control switches |
19th Dec 2016 7:52am |
Anything after mid 2009 uses the new system, only the older style steeering wheel controls will work with you vehicle.
19th Dec 2016 9:19am |
Smiffyuk2017 Member Since: 15 Mar 2017 Location: Grimsby Posts: 2 |
Unnecessary quote removed
15th Mar 2017 10:34pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
in the FTO is the triptronic trigger by a negative pulse ? |
15th Mar 2017 11:03pm |
