Home > Maintenance & Mods (L322) > oil change without ramps/lift
alistairh
Silly question time! I've just done my spark plugs,air filter and pollen filter and I'm contemplating doing a full oil change..is it possible to change the oil with the car in offroad height and with a couple of axlestands under the jacking points? Saves a bit more cash and it only leaves the mechanic the fuel filter,diff and gearbox oil change..I will change my oil filter at the sane time..any pointers would be appreciated ta...
Post #419165 22nd Dec 2016 3:44pm
You can do all of those oils yourself on your back with the car on the floor, just leave a door open and it won't drop, stick an axle stand under it if you like...
Gearbox transfer box and axles are straightforward....
All easy to do, details in Rave, make sure you can undo the filler plug BEFORE you undo the drain plugs..
Go for it... Thumbs Up Pete
Post #419170 22nd Dec 2016 3:58pm
alistairh
Brilliant! Going to order the extra oils today and have a swat up tonight...grudge paying for a job I could do myself...cheers Pete Thumbs Up
Post #419172 22nd Dec 2016 4:06pm
Do it like that every time, off road height and away you go .
Post #419207 22nd Dec 2016 7:56pm
belldarr
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
I bought a vacuum pump last year - perfect for changing the oil in any car and most dealers use a version of this.
Well worth it, I even replace the brake fluid and power steering fluid using it,
link to one on ebay
http://www.ebay.co.uk/itm/Sealey-TP69P-Vac...SwRgJXmcF-
Post #419209 22nd Dec 2016 8:33pm
As above and if you want more space park one sid on the edge of a curb for some extra clearance Smile as above it's easy when standard, I now have to put the front up on ramps due to the sump guard and needing to get it down first Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #419337 23rd Dec 2016 6:23pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Just watch the engine sump plug, they strip at piece rate.
The lower sump seems to be alloy and the plug isn't - recipe for disaster.
Ask me how I know Very Happy ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #419361 23rd Dec 2016 8:26pm
alistairh
I shall take a bit extra care then Thumbs Up Picked up 10ltrs comma oil as per the wiki chart and a replacement sump plug/brass washer also got a large mechanics oil pan ..the oil for the diffs is enroute as well...gentlemen again thanks a lot for the pointers/advise...
Post #419373 23rd Dec 2016 9:02pm
Clivefog
As it is only the gearbox access that requires something better that a squeezable I got the much smaller vacuum pump that transfers a litre at a time. It does do the axles and transfer box in one suck and blow which is a bonus. Sealey 1Ltr I think was £10 from the bay of e.
Post #419469 24th Dec 2016 4:44pm
sako243
Not ramps per se but I took a chainsaw to a 4x4" fence post, cut them into foot long sections with a 45 degree slope on one end. Nailed three together in parallel. Repeat 4 times.
Now I just put one in front of each wheel and simply drive up onto them. The extra 4" ontop of offroad height makes it much more pleasant moving around underneath. It's much flatter than the 110 meaning my arms tend to get jammed if I try and roll over. Ed
Post #419470 24th Dec 2016 4:45pm
I find that ramps really help with things. The added height and workspace makes things much easier. Si. <This is my name.
Post #419485 24th Dec 2016 7:37pm
