Home > Maintenance & Mods (L322) > Headlights 2010-2012 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
i can tell you without looking at pics that the headlight will be bi-xenon.. ... - .- -.
2nd Jan 2017 6:14pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Stan many thanks for your reply.Problem is that i have only main beam from hid bulb.Signal and high beam are from halogen bulb.Headlights retrofitted when i did the facelift.So can it be a wrong connection problem???? |
2nd Jan 2017 6:35pm |
sounds like the shutter isn't opening for the main beam...could be stuck?. ... - .- -.
2nd Jan 2017 6:39pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
If you're asking for MY10-12
2nd Jan 2017 10:06pm |
to clarify, for 2010-2012, the xenons [D3S] do the dip and main beam using a shutter system, the halogen [H7] does the main and flash..
2nd Jan 2017 10:16pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
yep Stan is right I have a MY 2010 and D3S does dip and main Geoff |
2nd Jan 2017 11:10pm |
Xenon is on for both dip and main, correct.
3rd Jan 2017 12:00am |
P 225 of the MY11 handbook
3rd Jan 2017 12:12am |
And just to confirm, I recently changed my xenon bulbs for osram night breakers, and the halogens for Phillips racing. They work perfectly.
3rd Jan 2017 12:26am |
rambles, i would cover your inner main lights with cardboard or similar and then try the main/dip on the stalk..this way you might be able to determine if yours work properly or not. ... - .- -.
3rd Jan 2017 8:01am |
Hi Ramples.High beam i mean the one when blue light in dash comes on.this one is halogen
3rd Jan 2017 1:24pm |
looking at your car profile it says you have a 2004, the headlights are 2010-2012, so is yours a front end conversion ? , if so then i think the conversion wiring might be at fault... |
3rd Jan 2017 2:00pm |
Right stan.As i mentioned above car is facelifted and i have used the attached diargram for connecting lights
3rd Jan 2017 2:18pm |
we're on the right track then
3rd Jan 2017 2:47pm |
