Home > Maintenance & Mods (L322) > dreaded Steering wheel drop
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
So after a year of pretty trouble free running I stop outside work, turn ignition off and the steering wheel drops onto my legs. A quick search comes up with the possible culprit and into the steering column I go. Yes the two legs have broken off so I move the brass nut over the remaining two to lock it in the high position. All good. Now my question is has anyone managed to replace the broken legs? My thoughts are leave well alone but if its a simple drill and a couple of self tappers I will do it. The other thought I had was to make a new nut and cut two grooves into it so it could sit between the remaining two legs. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #379125 24th Mar 2016 2:18am
wayneg
So attached is a video of the column being taken apart to change the bit with the broken lugs. Is this part now available as a spare?
https://www.youtube.com/watch?v=pSk6V9KezB0 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #379127 24th Mar 2016 4:27am
http://www.ebay.com.au/itm/Range-Rover-L32...7675.l2557
Uli ,makes them his name here;
http://www.fullfatrr.com/forum/member-meerbusch.html 2008 MY Supercharged
Post #379184 24th Mar 2016 11:02am
wayneg
Axle, thanks for the input. I am aware of that part and the seller, there is also a guy in America who makes that part in steel. Sadly that is for the reach mechanism, I need to fix the tilt, a separate motor and drive on the column as shown in the video 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #379286 25th Mar 2016 12:27am
Sharky1168
Expensive bit!
http://www.ebay.co.uk/itm/391658062069?_tr...EBIDX%3AIT Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #421806 8th Jan 2017 8:44pm
wayneg
Yes I have seen that for sale a while ago and though just way to much. I was going to try and fix mine at the time but ended up locking the wheel in the high position as thats where I have it anyway. An easy fix by moving the adjuster nut behind the remaining lug. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #421844 9th Jan 2017 1:19am
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Sharky1168 wrote:
Expensive bit!
45 quid postage on top of the purchase! Gawd! Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #421846 9th Jan 2017 3:09am
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
pretty sure that piece could be made easily in a workshop doesn't look too hard at all
Post #421847 9th Jan 2017 3:20am
wayneg
p38arover wrote:
Sharky1168 wrote:
Expensive bit!
A very good reason to turn off your Steering Wheel park function if you can or a least take off the cowling and give it a good grease. I live in hope a cheap option comes up or someone with a broken column would sell the bit cheap. No real hardship with it no longer moving though just a shock when the wheel hits you in the crutch Shocked 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #421849 9th Jan 2017 4:06am
