Home > Maintenance & Mods (L322) > dreaded Steering wheel drop |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
So after a year of pretty trouble free running I stop outside work, turn ignition off and the steering wheel drops onto my legs. A quick search comes up with the possible culprit and into the steering column I go. Yes the two legs have broken off so I move the brass nut over the remaining two to lock it in the high position. All good. Now my question is has anyone managed to replace the broken legs? My thoughts are leave well alone but if its a simple drill and a couple of self tappers I will do it. The other thought I had was to make a new nut and cut two grooves into it so it could sit between the remaining two legs. 2007 TDV8 VSE
24th Mar 2016 3:18am |
So attached is a video of the column being taken apart to change the bit with the broken lugs. Is this part now available as a spare?
24th Mar 2016 5:27am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
http://www.ebay.com.au/itm/Range-Rover-L32...7675.l2557
24th Mar 2016 12:02pm |
Axle, thanks for the input. I am aware of that part and the seller, there is also a guy in America who makes that part in steel. Sadly that is for the reach mechanism, I need to fix the tilt, a separate motor and drive on the column as shown in the video 2007 TDV8 VSE
25th Mar 2016 1:27am |
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 |
http://www.ebay.co.uk/itm/391658062069?_tr...EBIDX%3AIT Current RR L322 TDV8 VOGUE
8th Jan 2017 9:44pm |
Yes I have seen that for sale a while ago and though just way to much. I was going to try and fix mine at the time but ended up locking the wheel in the high position as thats where I have it anyway. An easy fix by moving the adjuster nut behind the remaining lug. 2007 TDV8 VSE
9th Jan 2017 2:19am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
45 quid postage on top of the purchase! Gawd! Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
9th Jan 2017 4:09am |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
pretty sure that piece could be made easily in a workshop doesn't look too hard at all |
9th Jan 2017 4:20am |
A very good reason to turn off your Steering Wheel park function if you can or a least take off the cowling and give it a good grease. I live in hope a cheap option comes up or someone with a broken column would sell the bit cheap. No real hardship with it no longer moving though just a shock when the wheel hits you in the crutch 2007 TDV8 VSE 2003 TD6 gone. 2002 P38a gone 1999 P38a gone 1997 p38a gone 1993 VSE gone 1992 VSE gone 1966 Series 2a with V8 conversion gone |
9th Jan 2017 5:06am |
