Home > Technical (L322) > BMW V8 alternator swap |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 354 |
Not that difficult. It's underneath the r/h cylinder head when looking at the engine from the front.
14th Jan 2017 4:27pm |
Dd5884 Member Since: 14 Jan 2017 Location: Suffolk Posts: 7 |
Thanks Zebedee. I've started today. However got stuck at the viscous fan removal. I've ordered a tool for it. Is it worth buying a quality alternator, seeing as it's a to get at ?
14th Jan 2017 7:28pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
In other words, under the left hand cylinder head. ** ** orientation is always as viewed from the driver's seat. Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
14th Jan 2017 10:38pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2024 |
Mark a spot on the bolt positions, as it's easy to bolt it in wrong. Also, take care to add some RTV, on the o ring, as it often leaks. Don't strip a thread, whole lower timing case will be required if you do. It's heavy, don't bash your rad. The fan nut get hit to the right, catch it with a thick gloved hand, so it also doesn't ruin your rad.. it can be fiddly trying to screw the fan back on. Take your time. |
14th Jan 2017 11:49pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
It's quite easy , when you have the viscous fan holding tool and spanner ..
15th Jan 2017 1:33am |
Thanks all |
15th Jan 2017 11:00am |
job done. Works a treat |
21st Jan 2017 8:35pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
@Dd5884,
18th Jun 2017 10:25pm |
