Home > Technical (L322) > 2009 RR g/box issue
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
2009 RR g/box issue
A chap round by me has a 09 rr and has issues with his drive he said and knowing ive had a few asked me if i knew anything about the drive train i said a little but will ask on the webs best forum i use Thumbs Up he's got a 2009 3-6 tdv8 showing 105k but when in 2nd and third about 1600 to 1800 rpm it gets a slight judder for less than a second like a gear whirr? alls fine and can hardly notice it when i went in it but it is slightly there, my mechanic said might be flaring on his torque c or any other clues i can tell him and possible issues or possible cost cheers guys Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #422892 15th Jan 2017 3:37pm
miggit
RRPhil is the chap to talk too, but I think that is the sort of issues that can be cured by a power flush of the gearbox.. Maybe specialist gearbox help is needed.. a normal garage is no good for these sorts of complaints Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #422939 15th Jan 2017 6:37pm
rar110
That era RR has the 6hp26 with the softer lead free stator bush. Ive read filings contaminate the tranny fluid and prematurely cause wear. Unless it's had a very early tranny service (say 30-40k miles) replacing the fluid will be a waste of money. ______________________________
Post #422960 15th Jan 2017 8:32pm
RRPhil
As rar110 has stated, there was an issue on some 6HP26 models with wear in the rear stator bush which allows the E-clutch circuit to leak and lose pressure causing the clutch to slip. However the E-clutch is only used in 4th, 5th & 6th gears so that sounds unlikely to be the issue here.
The torque converter lock-up clutch does seem like a possibility so, in the first instance, I’d be tempted to replace the EDS 6 (yellow cap) solenoid, which controls the torque converter lock-up clutch operation, knowing how prevalent solenoid issues are with the 6HP26.
Phil
Post #423018 16th Jan 2017 11:25am
Scottyav
I took him up to neil smith this morn and he tested it and said torque converter was slipping very very slightly but not to worry as it was minimal until it got worse, and it wouldnt damage any other parts of the box, usually its the carbon build up he said but overall quoted him 1100+vat for a reman converter gaskets filters oil etc, but would you try the eds6 valve first stil? thanks _____________________________________________________
Post #423057 16th Jan 2017 1:18pm
