Home > Technical (L322) > Gearbox ECU Errors |
Hi Guys,
14th Jan 2017 12:00pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
Certainly worth checking that they’ve got the connector back in properly.
14th Jan 2017 12:08pm |
I was hoping you'd reply Phil!
14th Jan 2017 12:16pm |
To be honest Dan I don’t have first-hand experience of this so I’m not sure. The workshop manual does give an indication of what view you get of it from underneath :
16th Jan 2017 2:01pm |
ipwn Member Since: 08 Aug 2015 Location: Yorkshire Posts: 48 |
Your issue above is the transmission solenoids. Replace them and all will be well. |
17th Jan 2017 12:04am |
OK, I reseated the plug and all was well for a day, thanks to Phil's picture above it is obvious the sleeve isn't seated fully as the gap is more like 5mm+
17th Jan 2017 11:52am |
craig nicholas Member Since: 08 May 2016 Location: Lancashire Posts: 32 |
Suprised the garage could push the retaining bracket for the electrical sleeve , 5mm is a lot . Glad you have a resolution to the problem though.
17th Jan 2017 1:28pm |
The canbus network connects all the ECU's together, it's the data connection that they "talk" on. When errors occur, it logs the exact mileage when the error occurred. Mine was full of errors along the lines of "Canbus Communication Error with TCM" (transmission control module) suggesting it was disconnecting. |
17th Jan 2017 3:48pm |
