Home > Technical (L322) > Toothed belt change 2011 4.4 TDV8 |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
Owned my FF for eight months, trouble free I thought until now. The cars in for service at an independent, being due an inspection 1 with 64000 on the clock. The machinic has noticed the toothed belt is starting to slip off it's pully, it's the belt which drives the power steering and alternator. I have authorised it to be replaced and the garage are awaiting parts.
17th Jan 2017 9:57pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3672 |
Someone with a better memory than me will direct you to a post by Craig some while ago describing the problem with the toothed belt guide, causing it to run off line. G reg 2.5VM Vogue Portofino red 1991- 1999
17th Jan 2017 10:09pm |
Thank you gents for responding, I feel a bit better informed now. The garage are intimating a bill of about £360 all in to do the belt job on top of the service. I can't work out why they work out why they feel they want to replace all of the pulleys just because tha have a bit of surface rust. |
17th Jan 2017 11:04pm |
most of the pulleys are plastic but tbh if they are replacing them all for that they are doing well, as I priced them up recently and the price for the parts was more than that. I would expect that sort of bill for just doing the belt and the tensioner, and the couple of pulleys you can get to easily. Stripping the other pulleys out is a bit more involved and many hours labour as one of them is on the alternator mounting bracket. There is nothing that can't be fixed with a hammer😜😜
17th Jan 2017 11:10pm |
Thanks for the additional info. It's my first RR and my first time at this Indy, always guarding against being taken for a ride with any garage having bad experiences in the past. Think this should be OK. |
17th Jan 2017 11:33pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
My 2012 4.4 has started squeaking likes it slipping, noticed the belt is half off the tensioner too. Need to get it looked at. 2012 4.4TDV8 VSE
19th Feb 2018 9:53pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
I was advised to change the idler pulley(s) if in doubt. Because if the belt goes it will cause collateral damage.
20th Feb 2018 8:02am |
carpcat Member Since: 13 Oct 2017 Location: Surrey Posts: 58 |
Tensioner and both belts changed on mine when the belt slipped off 2 weeks ago. No collateral damage luckily. Tensioner bearings collapse and throws the belt off. I had a strange whirring noise beforehand which I put down to the belt, but now realise it was probably the tensioner bearings on their last legs. First thing I knew the battery light came up on the dash, and power steering stopped working. Recovered to garage to fix. Chris |
20th Feb 2018 8:08am |
I am taking it into deals next week. I am assuming the tensioner is covered under the extended warranty. Mine is squeak, a spray of water quietens it for a bit. I am now nervous of it going now. Does anyone know how access able the tensioner and bolts are? It looks quite tight. 2012 4.4TDV8 VSE
20th Feb 2018 3:02pm |
My invoice was about 6 Hours work as the top coolant hose and fan cowling had to be removed, plus approx £200 parts Chris |
20th Feb 2018 4:18pm |
My car has been to the dealer. It requires a new tensioner and it is covered by the extended warranty. 2012 4.4TDV8 VSE
27th Feb 2018 4:18pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Does anyone have any pictures of what I should be looking for ?
28th Feb 2018 12:43am |
My car is at dealer so can’t get a picture. If you stand at the front looking towards engine, there is a gap on the right hand side between engine and radiator, get a torch and inspect the belt, look at the second pulley from the top, it is the tensioner and has no lip on the pulley wheel unlike the others. On mine the belt was running at least 20% off the this pulley wheel. The dealer said not to drive like this, if it fails there is 1metre of strong belt thrashing around in there. 2012 4.4TDV8 VSE
28th Feb 2018 9:43am |
OK, thanks. I will take a look at the weekend. Too many toys, not enough time
28th Feb 2018 2:26pm |
