Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 |
Guys, I've done a bit of homework on these, as previous posts, I was unsure of the size & material.
30th Jan 2017 12:59pm |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 183 |
Does anyone know if this repair would be covered by LR Extended Warranty? |
3rd Feb 2017 8:23am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
Should be as it's a failed part. Regards
3rd Feb 2017 8:54am |
mcspreader Member Since: 28 Jan 2017 Location: cornwall Posts: 52 |
What mileage can we expect to see this at? I have 69k and no sign. |
3rd Feb 2017 7:25pm |
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 |
Hi all my FF as got 93500 miles on the clock, and just starting to leak. Will do this next weekend
26th Feb 2017 8:24am |
Hi all I am just about to do this, I spoke to LR today to get a torque wrench setting for bolt that secures the union HS4 It is torqued up to 10Nm. Hope this helps |
27th Feb 2017 6:04pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
I replaced my O rings last night and in the process noticed that there is oil in my coolant, so it looks like I'll have to replace the oil cooler too.
8th Mar 2017 10:37am |
MJdronfield may be best bloke to ask as he had exactly that on his There is nothing that can't be fixed with a hammer😜😜
8th Mar 2017 4:41pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3660 |
What size o rings did you use? G reg 2.5VM Vogue Portofino red 1991- 1999
8th Mar 2017 7:35pm |
I used those suggested by Barry earlier in the thread: BS611 is a 8.73mm (ID Inside Diameter) x 1.78mm CS (Cross section) 'O' Ring.
8th Mar 2017 7:53pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2278 |
It's good to know that BS611 fits well - thanks for posting. |
9th Mar 2017 1:28am |
Mpirie, good tip about taping first groove.
10th Mar 2017 1:43pm |
Bought a bag of 10.......
10th Mar 2017 8:29pm |
Lol, don't worry, I have 8 spares
11th Mar 2017 9:17am |
