Home > Maintenance & Mods (L322) > L322 TD6 Oil change & all filters |
Ollie7195 Member Since: 11 Dec 2016 Location: Somerset Posts: 74 |
Hi everyone,
11th Feb 2017 10:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
done a good job there Ollie, i'll stick in the wiki.. ... - .- -.
11th Feb 2017 11:06pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Well done Ollie, thanks for taking the time.
12th Feb 2017 7:44am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
Nice write up.
12th Feb 2017 9:59am |
Thanks for the comments, just thought it may have been easier with the bonnet up but agreed it could be done with it in the normal position, interesting comment on the britpart stuff, have only had the car 2 months and hadn't seen any negatives about them till just now |
12th Feb 2017 10:53am |
Experience with Britpart tends to show that they are fine for some things but for others OEM is, in the longer run, the cheapest way to go. For me filters fall into that category.
12th Feb 2017 11:13am |
Will take note for next time fortunately the part numbers for the filters are for all makes not just britpart! |
12th Feb 2017 11:17am |
I have used bearmach in the past, I go for the mahle filters, oe if cheap enough, sometimes come up on ebay, my last fuel filter was a bearmach and fitted great, I had problems sealing the all makes one.
12th Feb 2017 6:56pm |
Judo Member Since: 24 Nov 2016 Location: Melbourne Posts: 14 |
Thanks for a great write up. -Justin
25th Apr 2017 4:22am |
Michel Member Since: 18 Jul 2022 Location: Belsele Posts: 1 |
Hey Guys, just finished mine ( Vogue 2004, 332.000Km, still running like new ) just one remark wich is often forgotten: also change the Cranckcase Breathing Filter ( on top off the cranckcase just before the plenum on right hand side) failing to do so may cause severe damage to your turbo over time. Regards and keep up the good tips! |
19th Jul 2022 8:19pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
The most common mistake first timers do is in fitting the new oil filter to the top housing, it needs to be fitted correctly and pushed in far enough to seat correctly... If you have not done one before then measure the distance shown in red here on the old filter and insure the new one is pushed home to the same distance...
19th Jul 2022 11:14pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Good advice there, couldn't agree more. |
19th Jul 2022 11:29pm |
