Home > Technical (L322) > Hazard light's issue
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
sorry if in the wrong section was a tossup between here or electrical section
I upgraded the rear lights to 2012 LED lights the front lights are upgraded to 2006 version (before I got the car)
so hazard light's playing up (can't add a video) indicator's work fine as they should no problems I have fitted load relays to the rear indicator wiring loom, however when you put the hazards on it double flashes then pauses instead of flash pause
anyone come across this before ?
car is 2002 bmw 4.4 V8
Post #429175 25th Feb 2017 9:47pm
alistairh
Strange one with the hazards also The fact your leds are still doing the disco thing even after the hot and cold monitoring been switched off ?
Probably unrelated but I had a faulty resistor that was causing occasional hyper flash and a pause in the sequence every now and again,Fitted new 15ohm resistors all was well and it happened again. Ended up installing interface boxes instead and I've had no issues..
Post #429178 25th Feb 2017 10:11pm
Lukie
the LCM has been switch off for the side light on both I think will have to double check they are the ones that pulse after starting the car
I get no hyper flashing on the normal indicators at all (for now) I have the fog light fix in place from powerful UK and indicator ballast resistors (again I think from powerful)
Post #429181 25th Feb 2017 10:32pm
Lukie
for those following I found out the issues was a setting in nav coder
Post #429900 3rd Mar 2017 8:15pm
n1cktdv8
check your inbox Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #429903 3rd Mar 2017 8:20pm
