Home > Technical (L322) > Roy Rangie is running on bump stops |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7724 |
Did you try searching ?
26th Feb 2017 8:57am |
koffeetemple Member Since: 07 Dec 2015 Location: Brookfield Posts: 7 |
it sounds like it is near the gear shift/dashboard area not from the back
26th Feb 2017 9:05am |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Locating the source of a noise from inside the cabin is almost impossible. What is the message on the dash? |
26th Feb 2017 10:01am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1335 |
I'd start by checking the compressor/air supply unit, but if you are hearing a noise from the front there is a cross-link valve at the front behind one of the wheel arch covers which might be relevant. Apparently it is a hassle to get at. Only Range Rovers since 1988 |
26th Feb 2017 11:23am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Re cross link valve:
26th Feb 2017 11:42am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Mine did this because of faulty height sensor.
26th Feb 2017 12:20pm |
Not everyone is on here 24x7 waiting to answer your questions - some of the most knowledgeable people may not even still be active members..... The most effective use of this forum is to search for similar issues people have had - if you can't find an answer, post as specifically as you can - what is the exact message, what have you tried & ruled out etc. It's very hard to diagnose vague problems remotely |
26th Feb 2017 1:09pm |
We all try to help and mostly get ideas.
26th Feb 2017 7:06pm |
