Home > For Sale & Wanted > (SOLD) BMW ULF bluetooth module, aerial and mic
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
complete bluetooth BMW ULF upgrade, this is the 4th gen (from memory) it dosn't work with my samsung S7 but if you use an older phone it should be fine
You will need to do the ULF wiring modification as shown in the fourm
the ULF connects in the boot, there aerial sit's on top of the satnav unit (wire should already be in boot) and the microphone that connects above to drivers head
the whole system for £50 postage £10
this item will soon be heading down under to a fourm member
Post #430785 11th Mar 2017 12:30pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Do you know if this would work with the mid rather than Nav unit?
Post #430873 11th Mar 2017 11:53pm
Lukie
I think it does but you have to buy a separate wiring loom again from memory it's not cheap (£70+) if you look in the boot on the left hand side put your hand down the inside of the pocket you will find a white multi connector this is where you plug the wiring loom in
here is a good guide for information
http://www.roverupgrades.com/Rover_Bluetoo...tions.html
Post #430940 12th Mar 2017 4:05pm
Lukie
still available
Post #435183 17th Apr 2017 1:21pm
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Will you post to Australia? Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #435263 18th Apr 2017 7:47am
Lukie
dont see why not, will have to look into it and find a price for you give me a day or 2
scrao that found price's aprox £10 to post signed for
Post #435311 18th Apr 2017 7:09pm
p38arover
Thanks Luke, received today.
Cheers
Ron Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #437802 10th May 2017 4:12am
