Home > Maintenance & Mods (L322) > Canbus Bulb fault
Danwilderspin
Canbus Bulb fault
hi all as part of my 2010 conversion I got some led fog that were canbus enabled... annoyingly they only use one feed for both light! this leave one unconnected and I get a bulb fault. I use these as drl so a little reluctant to put a resistor on as it will be on getting hot all the time... any ideas?
Post #430911 12th Mar 2017 11:00am
miggit
Have you installed the box of tricks that sorts the blinking fog lamp out? http://www.powerfuluk.com/vehicles/range-r...-cars.html Yesterday I couldn't spell Engineer... Today I are one!
Post #430931 12th Mar 2017 2:39pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Re: Canbus Bulb fault
Unnecessary quote removed
when fitting my 2012 LED lights I ended up buying 2 x resistors for the indicators and 2 x fog light boards
the other thing to do if you prefer is to get a copy of navcoder and program the LCM to not do checks on fog bulbs (most of my LCM checks are off)
Post #430943 12th Mar 2017 4:17pm
Danwilderspin
I have navcoder and could code that for the rear lights but not the front will have a look at the lonk
Post #430960 12th Mar 2017 7:59pm
miggit
Shocked We talkin bout the other end?? Rolling Eyes
And I can't see why you wouldn't be able to turn off the monitoring of the front fogs.. if the LCM can see it then you should be able to turn it off! That does not mean that they have called them by a different name Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #430965 12th Mar 2017 8:19pm
Danwilderspin
I would have thought that but no option on navcoder sadly. If anyone can get ncsexpert working on l322 then we may have luck but no one has I have found so far...
Post #430987 12th Mar 2017 10:43pm
miggit
Whistle I don't suppose that they are classing it as a headlamp? It's the only other option that I can think of, it must be monitored somewhere for it to give error messages, it's just a case of finding what they have called the bloody thing to start with Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #430988 12th Mar 2017 10:49pm
Lukie
I'm sure my navcoder read the LCM with front fog lights, as far as I know the front fog light LED conversion is ran by a ballast resistor similar to the indicator one not the circuit used for rear fog light
Post #431125 13th Mar 2017 10:56pm
Danwilderspin
won't that get mighty hot being on all the time?
Post #431154 14th Mar 2017 10:34am
Lukie
I would't have thought so, attached to the car with a gap between the ballast and mounting point should keep it cool enough, maybe email simon @powerful see his thoughts ?
Post #431227 14th Mar 2017 10:41pm
