Home > Maintenance & Mods (L322) > Fitting New Facelift air con controls to 2003 Vogue |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Nope I didn't get it sorted I have the exact same symptoms as you as per your video. I'm going to source a replacement as buttons are not great anyway. Seems weird auto button doesn't work like you I can only get 2 lights lit up turning knob and auto is stuck on. So like you I have just done a battery reset and issue still exists Present :2008 TDV8 HSE
23rd Mar 2014 12:36pm |
Me too Present :2008 TDV8 HSE
23rd Mar 2014 2:37pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
suspension knob conversion done
23rd Mar 2014 3:09pm |
Right had another look. I can get some sporadic movement and control with the auto button. I reckon once you open unit the cogs can become misaligned resulting in no action when turning the auto button. I have left it for today for fear of doing further damage. I think the only fix is a replacement panel or so I hope. The aircon works as it should in anycase so can put up with it for another while. Present :2008 TDV8 HSE
23rd Mar 2014 3:52pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Daveo how did you manage to convert suspension knob?you just replace it with a new type knob or converted the old one? |
14th Mar 2017 6:01pm |
hi
14th Mar 2017 9:57pm |
Thanks for your reply.Well noted |
17th Mar 2017 12:07pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
I switched my heater control unit over for a newer one and for a few minutes it did some strange things like flash the air con button without doing anything, but after restarting the car it seemed to work as the old one did, even with the different layout. It might be a BCU thing causing issues with the others.
17th Mar 2017 12:56pm |
Daveo just another question.If outer ring will be taken off from rear panel knob,which much cheaper to buy, will be ok sizewise for fitting it to susp knob ?(unfo donot know if front and rear knobs have the same dims)
Daveo please disregard my last question as i found in ebay the continental heating panels with quite ok prices and believe out of 5 knobs they have i will manage to safely remove at least one ring .
17th Mar 2017 2:12pm |
Daveo your lights please.
18th Apr 2017 10:02am |
Daveo sorry for the questions but obviously i am missing something.
18th Apr 2017 5:11pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
looking at you 2010+ panel this is not the right panel for the upgrade, the one you are looking for is 2006-2010
18th Apr 2017 8:11pm |
Kalimera.(Good Morning)
19th Apr 2017 10:01am |
