Home > Maintenance & Mods (L322) > Oil leaks. Please can someone help identify them please?
green-oval-nut
United Kingdom 2005 Range Rover Vogue Td6 Stornoway Grey
Hi, I have a 2002 4.4 V8 Petrol BMW engined Range Rover L322.
I have started seeing several patches of fluids on the floor, assuming it is coming from 2 places and running along everything else, then dripping on the floor. From the iffy pictures, please can anyone identify what it is that is leaking please?
My other half took the photo's as I cannot get down there or under the car. So I cannot identify the leaks myself at the moment.
Thanks.
Post #431700 20th Mar 2017 12:57am
holidaychicken
I can't tell from the photos on my phone but front of engine is normally upperbfront timing chain covers (big job) or if you are lucky just the vanos solenoid seals, sides and back of engine is normally cam cover seals and PCV system hoses deteriorated.
If it is around the drive shafts then there are seals where the driveshaft enters the diff
Post #431701 20th Mar 2017 1:08am
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I suspect a good degrease first then another look a week after that might help pick the source(s) of the leak. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #431704 20th Mar 2017 5:09am
green-oval-nut
Strangely it has stopped leaving oil puddles, and yes I checked the dipstick lol.
Post #433301 31st Mar 2017 2:44am
