Home > Technical (L322) > FBH Pre-Wiring? |
Is there wiring already in place for a FBH in the Petrol L322s?
12th Mar 2017 10:39pm |
I looked at that option but really wasn't keen on having to carry round diesel too. I had written off the idea of adding a FBH to petrol due to the coding of the car to accept it, but now I've got my head round that it's all good.
13th Mar 2017 7:29pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Tell me more of this." Coding" you speak of ??? No7 - 2003 V8 Vogue |
14th Mar 2017 4:41pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
You can, of course, legally use red diesel for the FBH |
15th Mar 2017 10:55am |
The Thermotop heaters burn 1 gallon for every 10 hours use. I'd spend more than a gallon of petrol driving to an agricultural supplier to find some red |
17th Mar 2017 9:50pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
yes wiing and plugs for the FBH are standard in all cars
18th Mar 2017 6:31pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Just to confirm are you saying you use a diesel FBH but are running it on petrol? Do it work correctly as they are labelled up differently for the 2 fuels. Would be interested to know how it performs running on the wrong fuel.
20th Mar 2017 1:16am |
yes you are correct
20th Mar 2017 9:52am |
this is very interesting, did you change any settings on the unit in order to get it to run on petrol or did you simply plumb into the petrol fuel line and fire it up?
20th Mar 2017 3:58pm |
Before I fitted mine to my old disco bus, I bench run mine in the shed with a gorilla tub acting as the cooling system. Things I discovered - there are only a few units that can be run without a can signal to activate, so if you planning on bench testing be aware. I made the mistake of buying one of the can units and ended up changing the board from a guy in Poland who builds his own controllers about £90 I think. The fuel feed pipe has to be the. Correct size otherwith the metering of the fuel delivery will be wrong. The burners a very simple to re build and clean out. After I de- coked mine it ran really cean with only a puff of smoke on shut down. The right units have a built on water circulation pump.I've got a rack of PDFs detailing wiring schematics and servicing if anyone want some bedtime reading ?
20th Mar 2017 5:15pm |
For reference, here is the link to the guy that does the replacement boards. The board he is advertising now has a option for diesel or petrol via a solder joint. I am going to have a look at mine to see if I have the same jumper to convert to petrol.............
21st Mar 2017 7:58pm |
i did not change any settings this it the unit i used to bench test the heater off the car http://www.ebay.co.uk/itm/BMW-K-bus-contro...1851&_ also the oval webasto controler will operate it (but only for 30 mins) http://www.ebay.co.uk/itm/WEBASTO-1533-Con...SwnH1WbAqC it ran for hours on petrol, derv and red derv no problem,heated a 25 ltr bucket of water up in around 6 mins and kept it at 78 deg till the battery went flat i just ran a new fuel line to the petrol pump housing on top of the fuel tank,drilled a small hole in the blanked off FBH take off , i drawed fuel up from the tank from the take off with less than 1/4 of a tank so i know the pipe goes down into the tank, bleed the fbh pump till petrol started to flow, thats it,runs like a gud un i mounted the FBH pump under passenger sill at the front for ease of accsess mine runs on lpg so the heater pipework is a work of art with the FBH connected so pictures would not be clear, but i got all the bits from LR off the parts manual and microcat |
22nd Mar 2017 5:27pm |
TOP replies guys, couldn't have asked for more! |
27th Mar 2017 8:15pm |
Quick question regarding the fuel pump:
2nd Jun 2017 9:29pm |
