Home > Maintenance & Mods (L322) > Fuel Gauge erratic |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
N.B. Mine is a 2011 4.4tdV8, with 64k on the clock. G reg 2.5VM Vogue Portofino red 1991- 1999
25th Mar 2017 10:19pm |
FD Member Since: 15 Jan 2017 Location: Bristol Posts: 31 |
Nice one, thanks Double_r |
25th Mar 2017 10:47pm |
jemj Member Since: 13 Sep 2012 Location: leighton Buzzard Posts: 54 |
Well it looks like I will be doing mine now as it has just packed up. It was reading good and showing that i had just under 100 miles left, I thought that I would fill up tomorrow but when I started it up to nip around to my sons house it read empty. I was hoping that buying a newer model with warranty that I would be spared the constant niggling failures that i have become accustomed to but alas, it is not to be. The Best 4x4 by far, so long as you have deep pockets. |
29th Jun 2018 8:43pm |
sniper Member Since: 21 Apr 2019 Location: london Posts: 23 |
Hi folks (i know this is an old thread) my L322 2012 RR Autobiography (with digital dash) reads full fuel (or near full) Fuel level ALL the TIME even after a few hundred miles from full fill up, the lowest it reads is like 1/2-3/4's full... how do i fix ?, im sure its a "stuck sensor" as i haven't used it for like 6 months and left it with a full tank of diesel... please help !! |
21st Apr 2019 7:53pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
You could take the inspection plates off and exercise the floats / sensors to see if it makes any difference. You could also measure the resistance across the two sensors and see if one is wildly out. There are threads on here that walk through how to do it. 2016 Skoda Octavia VRS Estate
21st Apr 2019 10:10pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
It's here on this thread, just read through from page 1
21st Apr 2019 10:15pm |
Soooo, i had a go, for others this may be helpful... you lift up the rear seats, remove the spare wheel cover, remove the rear seat locking brackets (large torx socket screw) remove the trim panels each side (partially, dont need to remove them at the top) then peel the carpet back (tie it to the folded up seats out of the way..)
25th Apr 2019 7:52pm |
Well done. Cheers, Greg
25th Apr 2019 7:55pm |
Swithins Member Since: 22 Oct 2013 Location: West Malling Posts: 145 |
I got caught with this last week in my 08 4.2sc . Unfortunately it was on a road just after a dual carriageway on Friday rush hour. Unfortunately the tailback I created managed to get me on the radio rac guy has no clue what had happened as my fuel gauge was showing 1/4 tank and I was on lpg when it died. No error codes on his machine. My specialist suggested 10l of unleaded which did the trick. He suggests that the lack of fuel may have caused a lack of pressure hence why it died despite running on lpg at the time. Booked in with him for later this month when he’s free. Current:
6th Jul 2019 10:23pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
My car has started reading half what it should do. First indication was today when the low fuel light came on, but reported range of 25 miles (half what it normally does when that happens).
19th Dec 2019 10:37pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1651 |
Hi John,
22nd Dec 2019 1:10pm |
Thanks Ash, great info.
22nd Dec 2019 4:25pm |
Alex5.0 Member Since: 18 Oct 2019 Location: Mainz Posts: 2 |
Hello,
31st Dec 2019 1:02pm |
Poprivit Member Since: 11 May 2014 Location: East Yorkshire Posts: 27 |
Had this on mine and it was the connector just as others have said. It’s just a pain to do and you need a low fuel level to do the passenger side. I used a transfer pump and was lucky to have a fairly low level so only needed to pump 20L out. Very poor design but easily sorted. |
12th Jan 2020 3:51pm |
