Home > Technical (L322) > L322 flat battery |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Anyone,
26th Mar 2017 9:25pm |
It was showing 12.6v on idle when revved it went up to 13.6v or there about so I know the alternator is charging.
26th Mar 2017 9:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Probably battery, possibly alternator.
26th Mar 2017 10:42pm |
12.6v is a little low, would expect mid 13v with the engine running.
27th Mar 2017 6:36am |
Yeh I'll turn everything on later and see if the voltage increases and go from their, but don't see why the steps stop working. Range Rover quotes.....
27th Mar 2017 9:56am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Was sitting in mine the ither day eith the iid tool plugged in and started playing with all the buttons.to see which one made the alternator work more. The front heated screen made the voltage jump by 0.6 , ( i presume to compensate for the draw on the battery ) by far the biggest jump of any toy in the car , maybe your wife put that on and it drained the battery ? 2015 4.4 AB
27th Mar 2017 3:15pm |
Well went to Halfrauds and they carried out a battery test and said the battery was fine and the AA guy said it was .
27th Mar 2017 5:13pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
There is a reset for the sidesteps if they are not working.Hold the sidestep button whilst torning on the ignition,hold for 15 seconds then turn off the ignition . |
27th Mar 2017 6:43pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 757 |
AA man is financially motivated to sell batteries. Batteries to the AA is same as PPI to the banks. |
27th Mar 2017 7:56pm |
The AA Man said he didn't have the battery anyway and after 3 minutes drove off. Range Rover quotes.....
27th Mar 2017 10:38pm |
Well I may of found my issue.
28th Mar 2017 11:22am |
Ummm cant see any reference to a 300 amp fuse anywhere in any manual, I'm wondering now if that's feeding some other axillary somewhere?
28th Mar 2017 11:54am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3186 |
That looks a bit "after market" to me. Has it been used to replace YTA000040? John
28th Mar 2017 12:46pm |
Charged battery and again the cars battery went flat. When I jump start the car the voltage on the battery is 10.6v or there about's but when I turn on all window demisters it drops to 8 or so volts.
28th Mar 2017 5:57pm |
