Home > Maintenance & Mods (L322) > L322 Coolant hose renewal schedule |
Nowhere in the LR literature does it say that any on the hoses need changing as a matter of course. Naturally some will go over time. Check the condition of the hose coming from the bottom of the coolant tank, it rubs through in some cases, if you rub your hand down it from the tank to the engine you may feel a groove where it's rubbing!
28th Mar 2017 7:59am |
L322 Newbie Member Since: 22 Mar 2017 Location: Boldon, Tyne & Wear, UK Posts: 26 |
Thanks for the advice, the expansion tank was replaced last week with the top hose from the radiator which burst. Will attempt to check the line you mention as soon as possible, I don't expect to be able to remove the headlamp this week, will report back when I know.
28th Mar 2017 8:44am |
jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380 |
Presumably you've had a sniffer test done to rule out a pressurisation issue causing the top hose to burst?
28th Mar 2017 5:05pm |
Many thanks, this test is something that hasn't been suggested to date- will ask the Garage to check this out as well.
28th Mar 2017 11:05pm |
Update
1st Aug 2017 7:24am |
Update,
30th Jul 2018 10:50pm |
