Home > Technical (L322) > Fuel Gauge stopped working? |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
........then it started again, stopped, started and stopped again (over a couple of days)
2nd Feb 2013 7:39pm |
On the couple of occasions I have asked for help rather than offered it the response both times hase been......well somewhat limited
10th Feb 2013 9:37pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Same thing happened mine although it was only faulty for about 3 days then corrected itself. Present :2008 TDV8 HSE
10th Feb 2013 10:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
reading through other fuel problems it could be the battery, low voltage possibly... ... - .- -.
10th Feb 2013 10:51pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Well, a big thank you to you, and all those that do post answers and info. It's much appreciated.
11th Feb 2013 1:03am |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 |
Having just dealt with fuel pump problems I know that the two right hand wires as you look down on the connector from the back of the car are for the pump motor it's self. They only show a current when actually cranking the engine.
11th Feb 2013 6:26am |
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 |
This is normal, no?
11th Feb 2013 10:49am |
I've just had a battery recall so it can't be my shiny new gel style battery
11th Feb 2013 8:32pm |
Not without removing it and checking the resistance, if that is even how they work these days. There is nothing that can't be fixed with a hammer😜😜
11th Feb 2013 8:46pm |
Freddie The Fish Member Since: 13 Apr 2017 Location: Bedfordshire Posts: 115 |
Did you find a fix for this, mine randomly shows empty then springs into life again ? |
17th Apr 2017 6:20pm |
It's a replace sender units job I'm afraid. There is nothing that can't be fixed with a hammer😜😜
17th Apr 2017 6:42pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
There was a guy who posted that the whole fuel pump unit inc sender was a BMW unit (could be correct for a circa 06 but not much later) and that he bought a non original replacement for a very reasonable price.
17th Apr 2017 6:56pm |
Try here: http://www.fullfatrr.com/forum/topic41996....l+pump+bmw
17th Apr 2017 7:03pm |
