Home > Technical (L322) > 'Scraping noise' offside wheel/s - sounds brake related |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Although mines a td6, I had this, it turned out to be the rear brake shield rubbing.
26th Mar 2017 7:40am |
Slaav Member Since: 02 Mar 2014 Location: GLos Posts: 32 |
Thanks - the level 4 mechanic/technician thought that may be it but it is now worse if anything - which I guess means it MAY actually be that but needs proper TLC ....
26th Mar 2017 9:46am |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 525 |
I've had a calliper seize a few times, twice on the rear once on the front - and that makes the noise described. The side that seizes (usually only one side of the calliper) wears its pad away and the scraping noise is the worn away pad scoring the disc. If you catch it early you may get away with just freeing off the calliper and a pad change, but more likely new disc, calliper and pads....
26th Mar 2017 12:30pm |
It's all within warranty but if brakes related, I'm sure it will be 'wear and tear'!!
26th Mar 2017 12:40pm |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 |
Probably the dust shield on the front ,one of the holes will have rusted round the bolt and it'll be moving and catching , quite a few threads on it in here , on my td6 I just cut them off and didn't bother replacing them. |
26th Mar 2017 1:25pm |
After my noise becoming unbearable and escalating this to LR customer services, it appears that the experienced ROADSIDE assistance chap, found it and sorted it.
19th Apr 2017 11:05pm |
