Home > Maintenance & Mods (L322) > Normal Battery Voltage needs for this beast
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
I understand these vehicles electrical systems are sensitive to battery voltages. Just noticed my iidtool shows my battery at 11.8 to 11.7 and in red when key on. But engine off. Charges fine and no problems starting. Battery getting too old for this car?
Post #435006 15th Apr 2017 9:42pm
England 2002 Range Rover HSE Td6 Alveston Red
What is the charge like from the alternator?
Test with engine running across battery terminals...
Have "IID non BT 02-05" & "RSW All Comms" in Hampshire - happy to help Smile
Also have VAG VCDS if you have an Audi/VW etc.
Always have comprehensive toolkit: hammer, duct tape, WD40 Wink
robertus-maximus - sollus-arbilla vagor stlata
Post #435009 15th Apr 2017 10:51pm
doclees
I will test across terminals when I get back home. Iidtool gives me a 13.8 to 14 v when engine running. Turn engine off and iidtool reads 12.2 and trickles down to 11.8 in about 3 min. When it drops below 12v the color goes from green to red.
Post #435011 15th Apr 2017 11:55pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Your charging voltage seems OK-ish. I'd be expecting 14.2 or a touch more just after starting. Static voltage of anything less than 12.6 V is less than ideal on a Fatty and can lead to starting difficulties and/or error messages.
If your static voltage is dropping to 11.8 three minutes after stopping engine then you have a current drain somewhere or your battery is knackered and isn't holding a charge.
Do bear in mind, though, that the IID tool itself consumes power so it is better to use a multimeter across the battery terminals to get an accurate reading. 2006MY 4.2 SC
Triumph Tiger 1050
1979 Pontiac Trans Am
Post #435101 16th Apr 2017 6:23pm
doclees
Thanks. Yes I was wandering how much the iidtool could be using. I will test across terminals tonight after everything stops whirring and buzzing.
Post #435104 16th Apr 2017 6:40pm
speedymarktd6
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
How old is your battery ?
Buy a new battery , put it on charge first till fully charged just to be sure then fit to Range Rover and see what readings you get i will never surrender to bling , mud and dirt all the way oh yeah . and pheasent blood in the back.
Post #435197 17th Apr 2017 1:19pm
RR2008HSE
There is a huge load on the battery when you start. An old, weak battery might be able to show 12 V on a meter, but not sustain it under a big load. There are fancy machine for testing batteries under load, but such a rapid loss of voltage would tend to indicate further investigation is warranted.
Post #435232 17th Apr 2017 7:10pm
doclees
Can't read the battery year. I'm guessing about 3 yrs old. PO would have put in new battery when purchased in parts. Resting volts across terminals is 12.33v. Only thing drawing power is the LED on the USB charging outlet.
Post #435259 18th Apr 2017 3:26am
mikeyyn
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
I have been playing with my IID today and have almost the same readings. After a few mins with the ignition on to allow reading of VIN and to allow unlocking of the new tool the voltage drops from 12.3V to less than 12V, shows red , pops back up to 12V and shows green and back again. Engine on shows 14.2V.
So, its either normal or we both have tired batteries.
Doclees, did you change your battery? 2011 MY Vogue 4.4
Post #435543 21st Apr 2017 11:00am
doclees
No I haven't changed the battery. I get 12.3 v across the terminals and it stays there through the night. The instrument cluster reads 12.3 v on startup too.
Post #435555 21st Apr 2017 2:14pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Not so, A great deal of electronics remains powered in order to accept commands (eg central locking, alarms, etc.)
Post #435862 25th Apr 2017 1:19pm
doclees
Yes I get that. I mean obvious things. Thanks though.
Post #435931 26th Apr 2017 1:47am
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
