Home > Technical (L322) > Issue when starting car when it's hot ! (FIXED PAGE 2) |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Thanks for your reply
17th Apr 2017 11:42am |
it may well be the coolant temp but when i checked the Code reader live data it read correctly for mine. but let me know if this fixes yours
21st Apr 2017 12:57pm |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 |
It amazes me that this seems quite a common problem (even across the BMW forums) and yet no one seems to have a definitive answer.
21st Apr 2017 2:20pm |
Jacckk Member Since: 31 Dec 2015 Location: Durham Posts: 18 |
I discovered that my warm start issue was actually caused by the LPG system. The diaphragm in the reducer was worn and was allowing gas to fill the manifold after the car was turned off, this would slowly leak away if left for long enough. I replaced the seals in the reducer and it's now perfect. |
25th Apr 2017 9:20pm |
I'm not sure about b348xyx, but I'm not lpg - just purely petrol. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
25th Apr 2017 9:26pm |
thanks for your update jacckk and glad you got yours sorted
26th Apr 2017 9:48am |
FIXED !!!! starts perfect every time now !!!!
27th Apr 2017 12:08pm |
Sounds good to me
27th Apr 2017 2:05pm |
heat from engine helps push the fuel back down the pipes ?
27th Apr 2017 2:08pm |
heres a video after car been left sitting for an hour after 20mins drive to get car to temperature.
27th Apr 2017 2:38pm |
Going to get a valve ordered 😀 Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
27th Apr 2017 2:41pm |
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 |
I have exactly the same "hot start" problem and have fitted one of these valves in an attempt to cure the problem but it hasn't made a difference.
22nd Aug 2018 11:07am |
