Home > In Car Electronics (L322) > My Reverse Camera Install |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
If you're just in the testing process, wise move!, could you not apply a known 12v feed to the camera to test that works, before you go pulling the wiring loom apart... When I do anything like that I have an Optima Yellow top battery that I use as a power source and for powering an inverter to power my soldering iron Yesterday I couldn't spell Engineer... Today I are one!
4th Apr 2017 8:34am |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
I posted last year about getting a TV upgrade and reversing camera fitted. I drove to Birmingham and waited, and well waited for 4 hours before they looked at the thing, very frustrated at this point, 2 minutes later I was told I have the TV digital upgrade already and they had tuned the unit - that all it needed, doh! - then that they were very busy and may not have time to complete the camera install. I was about to explode and was presented with a camera kit and a relay with how to wire instructions as a good will gesture/no hard feelings.
30th Apr 2017 1:41pm |
The red fly leads are to enable you to power the camera from the point of connection to the system or to send the switch signal to the head... I would use it to power the camera, that way you've only got to find a suitable earth Yesterday I couldn't spell Engineer... Today I are one!
30th Apr 2017 6:39pm |
Thank you that's cleared that up. Perhaps the fitters don't use them and that's why that was not explained on the diagram, who knows. |
30th Apr 2017 6:59pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Chaps....sorry to drag this thread up but I need some help. I replaced the failed LR camera last year. Stripped the housing and got a cheap ebay camera to fit, with guidelines. It's bugging me that the guides are not central and I cannot see the tow bar so I am thinking of extending the existing wires and replacing the spoiler mounted LR camera with a new and more appropriate solution. Ideally that solution will see the tow ball and have no guidelines.
9th Jun 2017 12:18pm |
You'll need an X5 camera like this one http://www.ebay.co.uk/itm/Car-Reversing-Pa...SwHoFXtE6l
11th Jun 2017 11:42pm |
That looks so much more usable than the original position and view. I'll take a look at this alternative I think. Do you have any info/tips on your install please?
12th Jun 2017 8:43am |
try this one !! http://www.ebay.co.uk/itm/Rear-View-Revers...-4ocFoISPg
12th Jun 2017 6:41pm |
Appreciate it's different but I assume you fed wiring down the upper tailgate? If yes, how did you remove that internal panel or was there another way of getting additional cable to the number plate light Is this where I put the car details and a bit about myself ?........ |
15th Jun 2017 9:00am |
The tailgate trim unclips, start at the top (bottom when tailgate is open!) the centre panel pops first, then the 2 sides and then the lower which you have to pop the lights out of first. There are wires running up the side of the tailgate and I just cable tied the camera wires to them, I also found that it's easier to feed the cables through the off side cable duct, and cutting off the plugs really helps... which as your connecting up to the factory camera wires, I imagine that you'll be hard wiring Yesterday I couldn't spell Engineer... Today I are one!
15th Jun 2017 9:10am |
I have those cream coloured panels off, the one I am struggling with is the large black panel where the lights sit, the one that's attached to the upper tailgate. there are 2 screw but it's rigid even when I remove them ! Is this where I put the car details and a bit about myself ?........ |
15th Jun 2017 9:29am |
I'm not the best person to ask about this as I don't have a reference source anymore... sold it last year.. I'd forgotten about the screws, I do know that it is held on with some very strong clips, like the door panels Yesterday I couldn't spell Engineer... Today I are one!
15th Jun 2017 10:23pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
miggit and Cliffy, any chance of updating your posts with new linked images? Imageshack has really screwed up the forum world. Ron B. VK2OTC
9th Aug 2017 5:25am |
Well I tried to download my album from Photobucket......
9th Aug 2017 11:18am |
