Home > Maintenance & Mods (L322) > Smoke from central vents on reversing |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
These are helpful and cheap. Also good for home colonoscopy!
23rd Mar 2017 5:22pm |
RoverP5b Member Since: 24 Jan 2017 Location: POWYS, Wales Posts: 9 |
That's a great idea, many thanks for the thought.
23rd Mar 2017 5:55pm |
Ever get this sorted? |
30th Apr 2017 3:13am |
All that smoke from oil has lined the vents. If you can clean them it will help. You may know how easy it is to get cabin air filter vents out and can also get to the firewall vents. BMW valve cover gaskets are problems for leaks as they age or are not seated well when installed. I clean both surfaces well and remove all oil with acetone. Then I use a thin film of RTV on the head and valve cover mating surfaces. Let it get tacky before placing gasket on. This will hold it in place. I torque to about 2 lbs ft short of recommended torque, wait overnight and finish torque. It is recommended to change the bolt grommets too but may be able to get 2 gasket changes to 1 grommet set change. |
2nd May 2017 2:38am |
