Home > Maintenance & Mods (L322) > Maintaining - looking for advice on maintaining L322 plastic |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 131 |
Just done mine this weekend with autoglym tyre gel and the other plastic bits on the car. Looks much better now 2012 Westminster 4.4 TDV8 (sold)
7th May 2017 9:22pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Anything you use on it will wear off qickly and it will be dull grey again in no time! Gtechniq do a product which is expensive but supposed to be a long term solution to dulled plastics which you may want to look up on google. |
Caddyshack Member Since: 03 May 2017 Location: Guildford Posts: 61 |
Yes, g technic is the product you need, I think it is c4, you only need a tiny bottle....it is like nothing else I have used before, forget plastic polishes, the g tech properly revives it. |
7th May 2017 9:29pm |
The main reason that the plastics go grey is because they continue curing with UV light so the oils come to the surface and get washed off. The g-technic stuff works well and I have found that it is much more permanent if you heat the plastic up before applying it - CAREFULLY !!
8th May 2017 10:19am |
buffalo4 Member Since: 01 May 2016 Location: Doncaster Posts: 143 |
Will the heat not deform the panel ? |
8th May 2017 11:29am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
I tried a host of treatments and then saw a chap on another forum using a matt black plastic paint. I have done the same and it looks good. Is this where I put the car details and a bit about myself ?........ |
8th May 2017 11:40am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
do mine every couple of washes with Autoglym - Bumper & Trim Gel
8th May 2017 11:52am |
Any brand Nick ? |
8th May 2017 12:42pm |
Bought the Gtechniq stuff a few years ago... Not even used it yet
8th May 2017 8:52pm |
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 |
try peanut butter smoth not rough |
8th May 2017 9:40pm |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 |
Or peanut oil. |
9th May 2017 12:38pm |
Yes still the only one I use it has nano technology and last quite a bit longer than others lol. |
9th May 2017 12:50pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Then your trim will be eaten by squirrels |
10th May 2017 2:17pm |
